Old 02-18-2011, 04:22 PM
play4theworld play4theworld is offline
Exclamation Creative Collection Install error
I get error 2147213312 when i install protools. I've installed it twice before on this computer and never seen this. I just got it back from toshiba with a new hardrive...
I know a lot of stuff isnt the optimal setup but it worked decent before I dont know what this is all about
SiSoftware Sandra
Computer
Model : Toshiba Satellite L655D
Workgroup : WORKGROUP
Host Name : AJ-PC
User : AJ
Processor
Model : AMD Athlon(tm) II P320 Dual-Core Processor
Speed : 2GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : MP Upgrade, Dual-Core
Integrated Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size
L2 On-board Cache : 2x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size
Computer
Mainboard : AMD Corp. Guam
BIOS : Insyde Corp. 1.70 09/09/2010
Bus(es) : X-Bus PCI PCIe USB
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : No
Total Memory : 2.75GB DIMM DDR3
Chipset
Model : Toshiba RS780 Host Bridge Alternate
Front Side Bus Speed : 2x 1.6GHz (3.2GHz)
Shared Memory : 256MB
Channels : 1
Memory Bus Speed : 2x 100MHz (200MHz)
Chipset
Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub
Total Memory : 3GB DIMM DDR3
Channels : 2
Memory Bus Speed : 2x 533MHz (1GHz)
Memory Module(s)
Memory Module : SanMax M471B5673FH0-CF8 2GB DIMM DDR3 PC3-8500U DDR3-1066
Memory Module : SanMax M471B2873EH1-CF8 1GB DIMM DDR3 PC3-8500U DDR3-1066
Video System
Video Adapter : ATI Mobility Radeon HD 4200 Series (40 SM4.1 500MHz, 256MB 2x533MHz, Integrated Graphics)
Graphics Processor
STREAM Processor : ATI Mobility Radeon HD 4200 Series (40SP 2C 500MHz, 256MB 2x533MHz, Integrated Graphics)
Storage Devices
TOSHIBA MK3265GSX (320GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 298GB (C:)
MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890ES (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (D:)
Logical Storage Devices
TI105828W0G (C:) : 280GB (NTFS) @ TOSHIBA MK3265GSX (320GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
TOSHIBA System Volume : 1GB (NTFS)
Optical Drive (D:) : N/A @ MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890ES (SATA150, DVD+-RW, CD-RW, 1MB Cache)
Peripherals
LPC Hub Controller 1 : Toshiba IXP SB600 SMBUS Controller
LPC Hub Controller 2 : Toshiba SB700 LPC host controller
LPC Legacy Controller 1 : Winbond WPCE775LA
Audio Device : Toshiba IXP SB600 High Definition Audio Controller
Audio Codec : Conexant 5069h
Disk Controller : Toshiba SB700 SATA Controller [AHCI mode]
USB Controller 1 : Toshiba SB700 USB OHCI0 Controller
USB Controller 2 : Toshiba SB700 USB EHCI Controller
USB Controller 3 : Toshiba SB700 USB OHCI0 Controller
USB Controller 4 : Toshiba SB700 USB EHCI Controller
USB Controller 5 : Toshiba SB700 USB OHCI0 Controller
USB Controller 6 : Toshiba SB700 USB EHCI Controller
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Atheros AR8152 PCI-E Fast Ethernet Controller
Wireless Adapter 1 : Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC (802.11g (ERP), WEP n-bit, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 100%
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 4.1
Old 02-19-2011, 06:14 AM
Default Re: Creative Collection Install error
nobodys knows about this?
I read what I could find about it. Most people fix it by deleting some kingston mouse drivers (don't have that mouse) and the rest call and get a new CD.
I'm planning to call monday but im not sure if I'll have to pay them or not.....how does avid customer support work?
Old 02-20-2011, 02:10 PM
Cant beleive this....
Old 02-28-2011, 10:03 AM
Just so anybody who has this problem knows, I did have to get a knew Pro tools installer so most likely its your disc if you have this problem.
Old 07-10-2011, 05:28 PM
pdot pdot is offline
thanks - i will try to get to the bottom of this, maybe a new installer will work...
Old 07-12-2011, 06:44 AM
Yea I called avid and got them to give me another installer download. Kinda hard to get someone to talk to w/o payin 60 bucks though.
AIR creative collection - cannot install lanstrad macOS 13 03-12-2015 04:35 AM
Install Error: 2147213312 for Creative Collection efrazier7 Pro Tools M-Powered (Win) 5 08-11-2010 07:18 AM
Install Creative Collection Only? DonM Pro Tools M-Powered (Win) 1 08-07-2010 09:35 AM
creative collection will not install....why? James522 Pro Tools M-Powered (Win) 3 07-17-2010 07:01 AM
creative collection will not install....why? James522 Virtual Instruments 0 07-16-2010 05:06 PM
