Old 02-27-2002, 01:01 PM
nutshell nutshell is offline
Default External Sources In
1. What are you all using this "In" for?
What type of equipment and applications?
2. Anyone burning mixes to an external CD Recorder? What is the path out?
thanks all!!!
I
Old 02-27-2002, 02:31 PM
Jan Folkson Jan Folkson is offline
Default Re: External Sources In
The external ins can be used for returning 3 2-track machines. I use mine for Dat, CD and Cassette.
I have a cdr connected to the digital outs of my first interface.
I'm not really sure why these questions came bundled in the same post, as the Control 24 has no output path per se.
If you need to connect to the analog ins of your cdr than you need to take the outputs from your 888 and patch them.
- Jan Folkson
www.janfolkson.com
Old 02-28-2002, 08:59 AM
McMasters McMasters is offline
I use mine like this:
---1-2 Ext CDR in
---3-4 Sub mixer in
---5-6 Headphone (cue mix) in
If I didn't do work in surround mode, I would have used protools source 3-4 or 5-6 for cue mixes.
It works for now.
Playing External Sources through the Eleven Unit QueueCumber Eleven Rack 6 06-18-2011 09:54 AM
External SCSI hard drive sources JNS Pro Tools TDM Systems (Mac) 6 02-19-2007 10:52 AM
Trouble using multiple external digital sources cprescott1972 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-02-2006 04:27 PM
Render Sources StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-24-2003 09:47 PM
Sources in the system stevegalante ProControl, Control|24, Command|8 1 04-29-2000 05:38 PM
