Old 03-24-2024, 04:01 AM
Je suis Je suis is offline
Default Eucontrol crashes Logic Pro
Eucontrol crashes Logic.
MACOS Ventura 16.5
3,6 GHz 10-Core Intel Core i9
I tried to use Avid Control App on Android to control my Mac DAWs.
When EuControl is running, Logic Pro crashes upon Launching.
Logic fully launches (also previous projects) but as soon as you make Logic the foremost Application by clicking on a window of Logic, it crashes.
I installed latest versions of both. I deleted all Preferences.
This happens as soon after I installed Eucontrol. Even if not launching Eucontrol. Only installing it is enough to crash Logic !!!
Premiere Pro works flawless with Avid Control App and gets immediately recognized by Eucontrol (since it has integrated Eucon Protocol).
Garageband launches, it connects but only transport works.
The SKEY buttons do show up in Avid Control (also when Logic launches) but they are non responsive.
Same with Ableton Live (via Mackie Control):
- transport works
- Tracknaming etc. work but Audio Meters do only show on track 1 (weird!!).
- Skey Buttons unresponsive.
What am I doing wrong?
Old 03-24-2024, 05:17 AM
tope d's Avatar
tope d tope d is offline
Default Re: Eucontrol crashes Logic Pro
MACOS Ventura 16.5
- transport works
Hi, are you on the latest version of Eucon?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-25-2024, 09:22 AM
EddieJones's Avatar
A few things:
It looks like you may have run into an Apple bug with their Security, Accessibility settings. Remove both MCClient and EuControl (minus) from these settings and then add back. That should get Softkeys working again for keyboard shortcuts.
Garrageband isn't EUCON enabled as far as I know.
We are currently working on improving Ableton Mackie Control
What version of Logic are you on? They did fix a EUCON crash in the newest version recently, we are also working on it our side too for the next release. It would be helpful to get any crash reports.
Eucontrol crashes logic when changing focus window mikaels_ Avid S1, S3, Dock and Control App 4 11-01-2022 05:08 PM
EUControl crashes every time. Jonothon77 Artist Series 6 03-13-2019 07:09 PM
Does S6 install Eucon/Eucontrol ? Logic crashes... vudoo Avid S4/S6 5 05-03-2016 10:46 AM
EuControl 3.2.2 crashes on quit LukeHoward Avid S1, S3, Dock and Control App 0 05-17-2015 05:24 AM
EuControl crashes on launch bizmar Artist Series 7 04-25-2014 12:01 PM
