Old 03-16-2024, 05:03 AM
cca102 cca102 is offline
Default MC_client error on eucon 23.11 version.
hello.
I install eucon 23.11 version.
But I can't run eucon with
EuCon client monitoring service detected a problem and will now exit.
Please check your network settings and connections
Error starting up MC_Client
So I searched for a solution and found it.
Avid Knowledge Base
MC_Client detected a network problem, Bad or Null CORBA POA
However, when I run it the way I did, I get an error as it is, and I can't find EuConStart in this version of the eucon folder.
How can I solve this problem?
I use window 10, AMD Ryzen 7 3900X.
well,sry. I confused the forum.
New version of EuControl & MC_Client dominicperry Pro Tools 5 02-11-2022 08:49 AM
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
Version Mismatch error with EUCON 2021.6 and Avid Control Babylonians Artist Series 2 06-30-2021 06:01 PM
EuCon version, Firmware and PT version Mark Ziebarth Avid Pro Mixing General Discussion 5 02-22-2018 11:10 AM
"incompatible EuCon version" error when launching Logic X MowingDevil Artist Series 6 12-01-2017 08:51 AM
