Old 03-11-2024, 10:05 AM
BiggiT's Avatar
BiggiT BiggiT is offline
Default Control surfaces loosing connection after PT 2024.3 update.
I hv S3 and a doc, and after this update EUCONTROL keeps loosing connections. S3 drops, Dadman looses connections, and sometimes pops back, PT looses connection... Its all a bit flaky now.
Cant seem to lock to PT ( like it was )
Like if I flip between PT and DADman S3 follows, Wasnt like that. It was locked to PT only - And yes I have locked DADman to monitor and Pro Tools 24 to transport in EuControl APPL ...
Am I missing something here ?
Old 03-11-2024, 10:09 AM
its2loud its2loud is offline
Default Re: Control surfaces loosing connection after PT 2024.3 update.
You probably need to add PT 2024.3 to the application white list in Eucon
Old 03-11-2024, 10:16 AM
BiggiT's Avatar
already did..
Old 03-12-2024, 07:46 AM
EddieJones's Avatar
Originally Posted by BiggiT View Post
already did..
You have DADman in there too...thats why. I presume you don't want to switch to DADMan tracks? Just want the Monitoring (checkbox)
Old 03-13-2024, 04:29 AM
BiggiT's Avatar
thnx
IM AN IDIOT :)
Old 03-17-2024, 11:02 AM
LesPaul2550 LesPaul2550 is offline
THANK YOU!!! Solved it for me. I wondered why my Application list showed Pro Tools 23Mac. I thought they forgot to update the name internally or something. My bad.
Quote from the movie Heavy Metal:
Den: "And if I refuse?"
Ard: "If you refuse; you die, she dies, everybody dies"
Old 03-25-2024, 10:51 AM
jschmit jschmit is offline
I'm still on PT Ultimate 2023.9 on a Mac mini i7 (OS 14.3). The Eucon checkbox keeps getting unchecked in PT Peripherals Settings. After I heck the box again I get connection between PT and the S1 units.
In some cases it's still checked but there's no connection to the S1 units. In those situations I've unchecked and closed the settings, reopened, checked the box again to enable Eucon and then it re-established connection. Anybody experienced the same thing? I'm not sure why this keeps getting fouled up but I need it to be solid so it doesn't throw students off when the start up the system.
Old 03-25-2024, 10:55 AM
EddieJones's Avatar
This is not expected. Do you have multiple users? Are they admin accounts?
Old 03-25-2024, 01:05 PM
They login to the Mac with the same user account that has admin rights. BTW when I open Eucon app settings it shows all the devices in that right hand window so they are seemingly active. It's just PT isn't seeing them for some reason. Luckily the Dock is connected with DADman so the control room monitor knob works.
Old 03-25-2024, 01:24 PM
EddieJones's Avatar
And you definitely have the correct PT version added to the Applications list in EuControl?
Control surfaces not working after PY 2024.3 update. filmixer Avid S1, S3, Dock and Control App 9 03-25-2024 02:37 PM
Artist control loosing connection planck Artist Series 11 07-08-2019 09:35 PM
MC Control & 2 MC Mix's loosing connection to PT9 RuffinMedia Artist Series 2 01-13-2011 01:14 AM
PT loosing connection with interface ericsvizeny Pro Tools TDM Systems (Mac) 3 11-25-2010 08:41 AM
Keep loosing connection with my 002 sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2005 05:29 AM
