Old 08-10-2020, 09:59 AM
firmflange's Avatar
firmflange firmflange is offline
Default Re: S1 recommended router
Hi Eddie, Yes, I connect both the S1 and the Dock to the router. It has 3 ports. Wish I could figrue it out.
When I had the Ariist Control, I would restart the router and the Artist, and there would be no latency for a short time, only to revert back to the same way. If I do that process now it continues to be latent.
These are the only things running on the network, so i wouldn't figure it would be like this.
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM
Slate Raven MTi2 / Artist Control
Old 08-10-2020, 10:06 AM
EddieJones's Avatar
Do you have Wi-Fi enable on the Mac? If so, try disabling it.
Old 08-10-2020, 03:31 PM
firmflange's Avatar
Eddie, My "Wi-fi" on the Mac is part of what enables the router. If I disable the Wi-fi, I disable the router.
I have no other network devices enabled.
Old 08-10-2020, 04:00 PM
EddieJones's Avatar
But you said you were connected by Ethernet to the router? It sounds like you need a better router though. Have a look at something like this with MU-MIMO features TP-Link Archer AC1200 and TP-Link Archer AC1900
Old 08-10-2020, 04:43 PM
firmflange's Avatar
Yes, I am connected to Ethernet by the the router, but the Network name is the same as my router's name. It might've been set up wrong by me. You are probably right on getting a new router.
  #16
Old 08-10-2020, 04:49 PM
EddieJones's Avatar
Have you tried to turn off the WiFi on the Mac...it should be OK
  #17
Old 08-10-2020, 04:50 PM
firmflange's Avatar
Can you steer me toward a good router name that would work with the Dock? I don't really know much about them.
  #18
Old 08-10-2020, 04:56 PM
EddieJones's Avatar
See the ones I suggested above
  #19
Old 08-10-2020, 05:22 PM
firmflange's Avatar
Would this one be effective Eddie?
TP-Link AC2600 Smart WiFi Router - MU-MIMO
  #20
Old 08-10-2020, 05:31 PM
EddieJones's Avatar
Yes that should be great.
Router, Hub, Switch? pasanta Artist Series 1 08-02-2019 12:22 PM
What router are you guys using? JCBigler Artist Series 6 12-16-2018 04:48 PM
Which router? Shatzer Artist Series 3 08-09-2015 11:26 AM
Mix on Mac: Only Router as Workstation ??? peterle Artist Series 1 12-16-2012 09:11 AM
looking for a router baadc0de Pro Tools M-Powered (Win) 0 05-10-2006 11:01 PM
