Old 03-13-2018, 02:13 PM
Bustback Bustback is offline
Default 2018.3 Edit window bug
When clicking on channel name or color to change it, whole channel list expands and turns solid white, blanking out whole list of tracks,names,I/O,etc... I can make it go away by changing channel view IE, adding inserts or I/O. So annoying!!
PT native 2018.3
MAC pro 10.10.5
Old 03-13-2018, 02:33 PM
climber climber is offline
Default Re: 2018.3 Edit window bug
Have not seen this.
Plus you don’t say what OS or platform.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 03-13-2018, 02:37 PM
Sorry it was my first post ever.
Old 03-13-2018, 04:15 PM
spock999 spock999 is offline
Got the same problem on my old Mac Pro 2008 I think I Fixed it by changing the Video Card. But I`m not 100% sure cause I did not have a lot of time to test it because I switch to my new PC Rig so maybe it was not really fixed after all but you can start with that
Old 03-13-2018, 05:05 PM
BScout BScout is offline
Originally Posted by Bustback View Post
PT native 2018.3
MAC pro 10.10.5
Not supported macOS.
Graphical issues are known if you use anything below 10.11 (and preferabbly 10.12 and higher) which is why they aren't supported.
Old 04-09-2018, 02:17 AM
jAZZbASS01 jAZZbASS01 is offline
I have also got this problem, and yes I am running mac 10.10.5, but the problem started with Protools 2018.1, prior to this it was fine, and as I have not changed anything it must be something that was changed in 2018.1 - 2018.4
Old 04-09-2018, 03:11 AM
Yes. Still not supported.
And Yes there was a major change for graphics and Avid posted it in their readme that specifically older OS versions would not be supported. If you would like to know why: it is because Apple has changed their GUI framework (API) to a system called METAL. And now Pro Tools takes advantage of the optimised 3D graphics by using METAL -- slowly changing things over since 12.8.2. Quartz/Core OpenGL was the API before up to Yosemite. Metal was El Capitan and Metal2 is High Sierra.
http://avid.force.com/pkb/articles/e...tibility-Chart
I don't get why people claim "it's a problem" when it is specifically stated not to use it on a certain OS. At that point, it's up to the user to make the wrong or right decision.
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
New Bug 2018? Edit window jump to vcas when clicking on plugins JuelzB Pro Tools 2018 3 01-19-2020 09:49 AM
Edit window zoom SLOW 2018.3 khoop2112 Pro Tools 2018 6 03-10-2018 03:34 PM
Link track selection from edit window to mix window? jaminjamesp Pro Tools 12 7 01-16-2017 05:37 PM
Midi edit window stuck to edit window lvsranch Pro Tools 11 7 04-04-2015 12:42 PM
