Old 11-09-2015, 07:14 AM
annaalex3 annaalex3 is offline
Default Command Shift K Not Working
Does anyone know why out of the blue "command Shift K" is not working? I am using Pro Tools 11 on an iMac running Yosemite. Thanks!
Old 11-09-2015, 10:58 AM
joachim's Avatar
joachim joachim is offline
Default Re: Command Shift K Not Working
You might check the clip list.
If the clips, you want to export, are not shown there, due to a clip list search that has not been cancelled or because the type of clip is not enabled in the clip list menu (show - audio, midi, ....), then those clips, who are only selected in the edit window, cannot be exported.
Cmd Shift K, that shortcut "belongs" to the clip list, not the edit window.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-10-2015, 08:16 AM
Does running the command from the clip list mini-menu work? If not, then it's probably something like what Joachim is suggesting. If it does work from the mini-menu, then it's probably an issue with a keyboard shortcut assigned in system prefs stealing it.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
the Shift+Alt+Pom+click command groovbro Pro Tools TDM Systems (Mac) 3 10-26-2008 06:45 PM
SHIFT COMMAND WHY germ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 12-12-2003 05:20 PM
Nudge vs Shift Command lcpellerin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2001 01:53 PM
Can't "shift-command-B" sometimes... dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-22-2000 11:38 AM
Losing [command][shift]B trombino Pro Tools TDM Systems (Mac) 12 07-12-2000 06:30 PM
