Old 03-20-2014, 12:50 PM
lltj56ace lltj56ace is offline
Default Re: ProControl with Pro Tools HD 8
yes the computer is reading the ilok and i do have the license
Old 03-20-2014, 01:14 PM
Craig F Craig F is offline
Originally Posted by lltj56ace View Post
no i don't have a core card or any accel cards yet and no pro tools will not load completely cause pro tools can not find the mixer when it is powered on the mixer is reading offline on the display screen.
You do not have a Pro Tools system.
You only have a control interface (the Pro Control)
A Pro Tools HD system pre version 9 has to have at least a HD Core Card, matching interface, and the HD license on the iLok
From version 9 on the software could run with out the Hardware but HD software licenses are not supose to be separated from the HD Hardware but some were
So what happened, someone sold you a HD8 License and a Pro Control and told you that you had a Pro Tools system? If so you got took
Thank you,
Craig
Old 05-04-2014, 10:04 AM
now that I have eeverything I need to make the pro control work, I was wondering do I need a mic pre to record vocals? and is the focusrite octopre compatible with pro tools 8 hd?
Old 05-04-2014, 10:52 AM
Default ProControl with Pro Tools HD 8
What exact HD compatible audio interface do you have connected to the HD/TDM card in your computer? The Octopre is not a HD compatible interface, but it can drive the line level analog or ADAT digital inputs on a suitable HD interface -- like a Digidesign 96 or 192.
This thread is pretty painful, we cannot guess what you have, or if you really know what "everything ... needed to make the Pro Control work" actually is. Or what you mean by "work" -- like what input and output IO do you actually need? How about you start over by clearly stating exactly what exact equipment you have and what you are trying to do (e.g. Track what sources, how many outputs, other digital IO needs etc.).
Old 05-05-2014, 11:40 AM
YYR123's Avatar
YYR123 YYR123 is offline
Painful indeed.....like trying to read and understand hieroglyphics.
Daniel
  #16
Old 05-07-2014, 06:45 PM
Hi its me again
I have a core card and the 192 interface got it connected with a digilink cable to primary slot but when I launch Pro Tools I'm getting a message "unable to find interface connected to first card check digilink and power cables then click ok to rescan" Do I need the other cards to make this work please anyone with knowledge on this please help this is becoming frustrating
  #17
Old 05-07-2014, 07:34 PM
As long as it's a Core Card and not a Proccess/Accell Card you should have everything
Things to try:
a) will DigiTest see the interface / check it's firmware version
b) try re-seating/flipping the Digi-link Cable
Thank you,
Craig
  #18
Old 05-07-2014, 07:49 PM
Hi its me again
It's likely as frustrating with the cryptic brief descriptions of your problems.
So lets see you got an error message telling you to check stuff, would it be too much to actually say if you checked that stuff?
Is this combination of card/cable/interface known to work in this or another computer? Not what you've been told by a seller but have you actually seen it working yourself?
So what exact trouble shooting have you done?
Where is your Sandra Report? (see the "Help us Help You - READ THIS Before Posting!" above on this and every other DUC web page).
Is the 192 plugged in and turned on?
Is the 192 Power LED ring lit up? And what color? And you've read the 192 manual to understand what the power ring LED color means?
Have you checked and reseated the Digilink cable?
Have you tried a different Digilink cable?
Have you run Digitest?
Have you checked the core card for common damage/broken components (e.g. http://duc.avid.com/showthread.php?t=281993). Check this before trying other slots.
Have you tried different card slots?
Have you tried a different computer?
  #19
Old 05-07-2014, 08:48 PM
YYR123's Avatar
Nope that's all you need. Is your card passing digitest? If you don't know what that is, check your manual for full instructions
Daniel
  #20
Old 05-08-2014, 04:18 PM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Our Octopre is an ADAT Only unit. Thus in this setup it is only connected via ADAT, so any brand ADAT unit would be compatible.
Best regards.
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Control|24 and ProControl with Pro Tools 11? xStix99x ProControl, Control|24, Command|8 2211 04-29-2019 01:23 PM
ProControl in Pro Tools 9 BejankaMop ProControl, Control|24, Command|8 5 11-12-2012 01:31 PM
pro tools hd 9 and procontrol djgusmusic macOS 0 07-10-2012 09:11 AM
Pro Tools HD2 8.1-9.0 using ProControl jpd52 Pro Tools TDM Systems (Mac) 0 01-22-2011 06:37 PM
ProControl working with Pro Tools 9 brdst Post - Surround - Video 1 11-08-2010 02:49 PM
