Old 03-04-2014, 05:00 PM
lltj56ace lltj56ace is offline
Default ProControl with Pro Tools HD 8
I have the Pro Control mixer and I can't get pro tools 8 hd to find it when i open it I have the ethernet cable connected to the mixer from my computer. Am I doing something wrong? or do I need something else?
Old 03-06-2014, 08:46 AM
bcwiz's Avatar
bcwiz bcwiz is offline
Default Re: ProControl with Pro Tools HD 8
Just a guess; for direct connection to a computer you need a crossover ethernet cable (usually red). Use standard ethernet cables when using a hub.
Old 03-07-2014, 03:35 AM
elicious elicious is offline
can't tell from his post;
did you "enable" ethernet from peripherals?
e
ihatetyping
Old 03-18-2014, 04:26 PM
Honestly is there anyone who has knowledge of the procontrol mixer by digidesign I have pro tools 8 hd and i'm using the procontrol mixer. my question is why won't pro tools connect with the procontrol? everytime I open pro tools I get the message pro tools to connect hardware and click ok. I'm i doing something wrong or do I need more components to make this work? please help please
Old 03-18-2014, 04:44 PM
crizdee's Avatar
crizdee crizdee is offline
You don't need anymore components?
Are you definitely using HD? As I'm not sure the driver was included with LE
Should just boot pro tools and go to setup>peripherals>Ethernet controllers. And run scan and it should find the pro control connected as a device! If it's not seeing it then either the driver is not installed as part of pro tools or the Ethernet cable or Ethernet port is not working right.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-19-2014, 05:35 PM
I understand what you mean now I just need to figure out how to get the Pro Control on-line cause it's saying off-line now. That would be a great help if you could explain that to me.
Old 03-19-2014, 07:10 PM
Craig F Craig F is offline
?s
Mac or PC
straight cable or through hub or switch
regular or crossover Ethernet cable
was it working for you before
if you just bought it did you see it work before you paid for it
do you have the Loop-Back test plug
Thank you,
Craig
Old 03-20-2014, 12:26 PM
I have mac pro I have a crossover cable and yes it came from a working studio and no loop back test plug I can't access the paripheals cause i can't get pro tools to load cause it can't communicate with the mixer, so is there another way i can get enable the ethernet port in pro tools?
Old 03-20-2014, 12:36 PM
Pro Tools is not loading at all?
The Pro Control is most likely not your problem, it's an extra
Let us brake this down:
1) So you have X computer with your HD Core card and maybe some Process/Accel cards?
2) The cards pass Digi Test?
3) Your Computer is seeing the iLok and it has the Pro Tools HD8 license on it?
4) Will Pro Tools open w/o the PC connected?
Thank you,
Craig
Old 03-20-2014, 12:49 PM
no i don't have a core card or any accel cards yet and no pro tools will not load completely cause pro tools can not find the mixer when it is powered on the mixer is reading offline on the display screen.
Control|24 and ProControl with Pro Tools 11? xStix99x ProControl, Control|24, Command|8 2211 04-29-2019 01:23 PM
ProControl in Pro Tools 9 BejankaMop ProControl, Control|24, Command|8 5 11-12-2012 01:31 PM
pro tools hd 9 and procontrol djgusmusic macOS 0 07-10-2012 09:11 AM
Pro Tools HD2 8.1-9.0 using ProControl jpd52 Pro Tools TDM Systems (Mac) 0 01-22-2011 06:37 PM
ProControl working with Pro Tools 9 brdst Post - Surround - Video 1 11-08-2010 02:49 PM
