Xpand on pro tools 8
Help! Can't really seem to find the right answer so I'm posting a thread of my own! I am on pro tools 8 and running on max osx version 10.6.8
I am trying to open expand. I go to create a new stereo instrument track and then when I go to the view window and try to pull the instrument viewer via xpand it is not working at all. I think I installed xpand correctly? When I go to the finder in my mac it recognizes the xpand plug-in. I don't think pro tools is however. Help a newcomer out!!!! :) |
Re: Xpand on pro tools 8
when you create the stereo instrument track, are you adding Xpand in the sends?
Are you able to select it from the sends menu? Does it not show up at all in he sends menu under instruments? Chris
http://www.youtube.com/user/RegenerationMix http://soundcloud.com/regenerationmix http://twitter.com/regenerationmix MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7 |
No it doesn't . However xpand is on my computer so that's why I'm
Confused ? If I go to my applications/digidesign folder and it's there . |
are you on windows?
on a mac the actual dmg file should be in your digidesign/protools/plugins and in digidesign/protoolscreativecollection/xpand2/xpand2.big im not sure you have it installed correctly. If you are windows, i do not know the directory path. Someone else will have to post that. regardless, it should be in your plugins file. Chris
Pro tools 10 and xpand 2 | 1ndn | Windows | 3 | 03-05-2014 02:32 PM |
Pro Tools LE 8 Stalling at XPAND!.dpm | fredmarzin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-29-2011 03:07 AM |
Xpand in pro tools | kedaniel | Tips & Tricks | 1 | 05-04-2010 04:48 PM |
pro tools 8 xpand not working | ukemasta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-03-2009 02:25 AM |
Using xpand with pro tools 7.0 HELP | JRJones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-06-2006 12:33 PM |
