my virtual instruments wont work
After installing protools 10 from a download I downloaded the virtual instruments . They won't work. Help
Re: my virtual instruments wont work
We cannot guess what you are doing.
How experienced with Pro Tools are you? Do you know how to use VIs? Are you followed any documentation on how to use them? -- at what point to things diverge from what you expect/what is documented? Do all other things in Pro Tools work OK - basic audio recording/playback? MIDI recording/playback? Where do you have the VI plugin inserted? Describe exactly what are you doing. Read this Help Us Help You and follow the suggestions there and also try to provide as much of the information asked for there. |
Protools 10 works. I've played the demo. After installing the virtual instruments I followed the guide to make a beat with expand 2. Every thing loaded fine but I get no sound
Are you familiar with (other) VIs in Pro Tools? Does your system seem to record and playback audio tracks properly? (i.e. checking if basic playback/monitoring works). Where is the VI inserted (insert, send?) on what type of track? (instrument, midi, audio)? Do you see meters moving or just don't hear anything? Lets do the simplest test: Try creating a new mono instrument track and inserting the mini-grand VI in an insert slot. Don't change anything in the VI. Can you hear (and/or see on the track meter?) notes play when you mouse click on the keyboard in the plugin? What manual are you following as you try to use this? Darryl |
PT Express virtual instruments wont install | joebejeckel | Pro Tools Express on Windows | 3 | 01-08-2014 02:19 PM |
Virtual instruments that actually work in Protools 10 | kennethmccorvey | macOS | 2 | 03-26-2012 12:42 PM |
PT 9 and Virtual Instruments | Baumtracks | Pro Tools 9 | 11 | 01-07-2011 04:55 PM |
Need Help - Creative Collection´s Virtual Instruments wont load! SOLVED | hernan1987 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-11-2009 08:14 AM |
Best virtual instruments? | el biciclista | Virtual Instruments | 3 | 12-06-2006 02:03 AM |
