Transfuser feature requests
I stumbled upon a list of feature requests for Transfuser I compiled in 2009.
From the looks of this forum and Avid generally I think I already know the answer, but hey - does anyone using the $99 1.3 update know if any of these made it in there? Here's the thread: http://duc.avid.com/showthread.php?t=231890&page=3 1. The ability to drag'n'drop/swap around Drum Pad FX. 2. The option to make Drum Pad send fx *post* volume/pan - so lowering a Drum Pad's volume also lowers it's send FX and changing a Pads pan setting is reflected in the Send FX. 3. The ability to drag a wave file from the Recorder into a User Audio folder in the Browser. This makes the inability to save your own Drum Pad creations slightly less painful to workaround. 4. The ability to save your own cool Drum Pad creations - is there no way that a wholly self-content file can be saved with FX/envelopes etc? 5. Most importantly, the ability to increase the Sequencer Pane to allow all Drum Lanes to be seen. I can't emphasize how crippling it is to not be able to see all the Sequencer Lanes at the same time. 6. Ditto using slices, trying to line up the desired slice to the right step is very fiddly with the present pane size. 7. Audition Browser samples *with* Insert/Track/Master FX. I very often find a cool snare only to find that with enhancers/compressor/maximizer on the FX it sounds completely different. Also audition Browser samples in situ ie temporarily replacing the destination Drum Pad as the Drum Seq. 8. An option that when you select a slice it sounds/plays. Removes the need to audition it via the vertical piano of the piano roll and then hope that you've selected the right slice. 9. Being able to drag along a Sequencer Lane with the pencil tool, creating or deleting notes as you can in the Transfuser effect "Gater" would *greatly* speed up writing. 10. Also, having the most frequently used commands such as Copy/Paste current bar, Undo/redo, *deselect* brought out onto the GUI would, again really speed up the workflow. 11. The ability to mute/solo the different FX lanes in the Gater effect. 12. A Mario-like function for use with the gater- ie randomize option for each lane. 12. Mono/Stereo output button on each Drum Pad. 13. Back and forward arrows for Drum Synth Kits (above the drum pads) For the FX presets. 14. Reverse and Note Repeat (a la GURU for glitchy effects) pages in the Drum Seq. 15. Copy and paste Track Automation Lanes. Copy Automation Lanes steps 1-16 to 17-32 and vice vers 17. Ability to save *User* FX presets. Also, FX "init" presets. (for Gater, for example.) 18. Pressing Record in Transfuser and then Play in Pro Tools starts Transfuser Recording - with subsequent trigger notes from a MIDI region change the pattern in Transfuser - enabling one to play/record into Transfuser while listening to the whole Pro Tools session. ie "wait for note" Record mode with proper pattern change. 19. Also, being able to play/Rec a pattern when it has no data in it - at present you have to draw in a note before it'll play. 19. Create cresendo works based on the current Page selected ie if filter is selected then it creates a filtered crescendo, ditto pitch etc 20. Altering the settings on the Pitch etc page using the mouse is set to the slower setting, currently *always* requires a key modifier to enter the inevitable small change. 21. Drag and drop FX *exchanges* them rather than overwrites. 21. A Fine Tune page or alternative setting for the Pitch page.. 22. Selecting or "highlighting" some lanes and choosing "copy current bar" and then pasting into a new bar *shouldn't* overwrite unselected lanes - thereby allowing one to copy and paste different lanes into different patterns and combine the best of both. 23. Right-clicking with the pencil tool deletes a node (ie slicer pan node) or note. 24. Option to turn off scroll while recording. 25. If left-clicking a lane in a Drum-Synth "Selects" all on that lane can we have right-clicking "Deselects" all - much, much easier than constantly having to go to the drop-down menu. 26. Ability to save Drum Pad Send FX and Insert FX set-ups. 27. In the Drum Synth display for each sample, having the wave overlayed the pitch/amp/filter thereby making sound design much easier. 28. At present it's impossible to draw nodes in the Drum Pads pitch/amp window in the *upper* far 3rd of the screen where the samples name is - and therefore deleting is also difficult if the zoom places a node in that area. 28. The drag'drop of Drum Pads has been unexpectedly removed with no explanation. The proposed solution unfortunately doesn't copy the old Pads pain-stakingly tweaked FX or sends - which also of course cannot be saved and reloaded into a new Pad. A more elegant solution would be to have an option on the Tool(?) page which "Enables Drum Pads to be *swapped*" thereby also removing the danger of accidently copying over an existing Drum Pad. 29. The ability to copy and paste a single Drum Seq Lane into another single Lane on multiple or single pages- ie doubling up a kick Lane at the moment including all the velocity/pan/time information seems impossible, ditto trying out a Lane with a different sound etc. 30. Sample start and end midi learnable/Track Automation Lane usable 31. In the Drum Synth be able to load new samples leaving the destination Pad's FX and enevelopes intact. 32. Gater FX - copy/exchange/swap pages 1 and 2 |
Re: Transfuser feature requests
Lots of good points made here. I feel the same way, as good as this instrument is it could function better with simple upgrades. ie. pitch bend amount, being able to move the pane to see what the file is.....
Feature requests | Dopamine | Pro Tools TDM Systems (Mac) | 24 | 03-16-2010 12:41 AM |
Two feature requests | RobMacki | Pro Tools TDM Systems (Mac) | 13 | 07-08-2006 03:11 AM |
Bugs, feature requests and tip requests! | Basil Rush | Pro Tools TDM Systems (Mac) | 6 | 12-07-2005 08:21 AM |
new feature requests! | mattm | Pro Tools TDM Systems (Win) | 0 | 04-12-2002 10:42 AM |
FEATURE REQUESTS FOR 5.1 | Bryan | Pro Tools TDM Systems (Mac) | 19 | 12-13-1999 02:11 AM |
