Old 08-10-2011, 08:17 AM
guitar1965 guitar1965 is offline
Question Macbook Pro / Pro Tools LE 8.0.5 and configure options?
I am using a Macbook Pro for recording - (specs below) and am using Pro Tools LE 8.0.5 (I am new to PT, so I am a newb). Mainly guitar and vocals. This is my only setup to record, so my options are limited.
Macbook Pro 15 inch (mid 2009)
Intel Core 2 Duo
2.53 ghz
4gb mem
250 gb hard drive 5400 rpm
2 USB / 1 Firewire port
Should I be using an external hd just for audio recording? I assume yes, so what is the best option for external hard drives, setup, etc.? I am using the new Mbox 3, so that takes up one usb port. If i am using both usb ports or 1 usb and 1 firewire will that hinder anything? Thanks.
Old 08-10-2011, 12:29 PM
Angelo of Onello Angelo of Onello is offline
Default Re: Macbook Pro / Pro Tools LE 8.0.5 and configure options?
using an external HD is the best route. i have a Digi 002, which uses 400 Firewire, i write-to an external 1TB HD with an 800 Firewire. i'm sure it'd be fine with 400 FW too.
when you start a new session, save it to the external drive. and it'll run off of there.
i use a Buffalo 1TB drive, but honestly man, any firewire external HD will do, just make sure it has good ratings. you can hit up newegg[dot]com for some quality gear at decent prices.
- Angelo
Pro Tools 9.0.5
Digi 002 Mixer Console
Mac Book Pro 2.33
Snow Leopard
www.blitzvixen.com
Old 08-10-2011, 08:58 PM
Thanks - I'll look into some firewire options.
How to configure USB ports on MacBook Pro? patspahr9 Getting Started 8 12-12-2013 03:48 PM
Macbook Pro - Make the most of your I/O Options Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 30 02-22-2011 10:10 AM
How to configure Firestudio 26 on Pro Tools 9 nohayniunnick Pro Tools 9 2 11-24-2010 02:02 PM
Best way to configure new macbook pro, mbox 2 pro, external firewire hard drive? Schragermeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 59 07-11-2009 08:01 AM
Help Me Configure a new Mac Pro for Pro Tools! raydsr Pro Tools TDM Systems (Mac) 5 04-06-2009 09:42 AM
