  #21
Old 04-02-2011, 05:45 AM
denka's Avatar
denka denka is offline
Post Re: PT9 Command 8 with another control surface
Originally Posted by DigiTechSupt View Post
Sorry about the delay in getting to this one - I've had a huge queue to try to get through since Pro Tools 9 launched.
The short answer to your question is 'Yes', though you can't use 2 C|8's together. You can, however, use a C|8 with MC Mix, MC Control, etc.
Here's how I would use it - go to Peripherals>MIDI Controllers and enable the C|8 in the first slot.
If you have an MC Mix, MC Control, etc. attached go to Peripherals>Ethernet Controllers and enable EuCon.
I'm working with an MC Mix, and MC Control and a Command|8 attached. Once you do the above, you'll see that all 3 units show the first 8 tracks of your session (well, the MC Control will show the first 4). If I wanted to have each unit 'start up' with a particular set of tracks assigned you can bank to the selected tracks on the MC Mix or MC Control, then go to EuControl Settings and the Layouts tab - and store your layout. I set mine up so the C|8 is controlling the first 8 tracks, the MC Mix the next 8 and the MC Control the next 4. !
I bought MC MIX yesterday, did what DTS suggested here and Command8 and MC MIX work together almost great. "Almost" means that all 8 output leds on C8 don't work while EUCON is enabled in PT 9.0.2. I use 2.5.7 version of EUCON.
Anybody experienced this?
btw, I wish we could use 2 c8s... Artist series looks like a toy comparing to C8...
AVID HD Native PCIe + HD OMNI; Digidesign 192 I/O (2x) & 96 I/O; Icon QCON Pro & QCON EX; Softube Console 1; NI Kontrol 25; Arturia SparkLE; UAD-2 Satellite DUO; UAD-2 PCIe DUO; Tascam DA-3000; TK Audio BC1-S; Warm Audio WA76; SSL XLogic Alpha Channel (x2); SSL X-PATCH; Lindell Audio 6X-500, 7X-500 & PEX-500 (all x2), lots of TCE & Lexicon reverbs; VintageMaker LittleOne 16/2 Summing Mixer; MUTEC MC3+ SmartClock; Mac Pro (2009) 8 Core 2.26; 24 Gb RAM; Pro Tools HD 12.8
  #22
Old 04-13-2011, 07:40 AM
denka's Avatar
Default Re: PT9 Command 8 with another control surface
Hello DTS,
Will you finally explain me why the I/O leds on Command8 don't work when MC MIX is added to the system?
  #23
Old 11-25-2015, 12:35 AM
Bill Rigby Bill Rigby is offline
Command 8 Manual Page 13
003 or Digi 002 and Command|8
When used as a MIDI control surface with a supported 003 or Digi 002® system, the faders on Com-
mand|8 function as additional faders (9–16). Figure 2 shows fader mapping when Command|8 is used
with a 003. (Plug-ins cannot be edited on Command|8 when used with a 003 or Digi 002.) You can
use Command|8 for expanded fader control, or for remote transport control and monitoring
Does this mean I will able to use my Mackie HUI with Command 8 as a bankable 8 faders?
Do I need to put it into standalone mode?
Focusrite Saffire Pro 40 and Command|8 Control Surface EmperorMusic Third Party Interfaces 2 02-15-2014 11:22 AM
Can you bring an audiosuite plugin under d-command surface control paulroberts ICON & C|24 0 03-22-2010 01:24 PM
Control Surface Question: Command 8 and Frontier Tranzports solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-09-2008 02:41 PM
Control Surface - Command 8 vs. Mackie Universal?? doylemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 02-24-2006 03:21 AM
New command 8 control surface blue demon General Discussion 13 04-07-2004 09:03 PM
