  #21
Old 08-26-2010, 08:11 AM
CyrilJohn CyrilJohn is offline
Default Re: PT 8 Wont recognize COmmand 8
I have got the same problem,
But when I wanted to check the links they are no longer available because they're on the old digidesign site,
Could you provide a working link how to solve the problem?
I have already tried to reinstall but didn't help.
Thank you
Windows 7
PT 8.04 LE
  #22
Old 10-22-2010, 12:49 PM
davetherckstar davetherckstar is offline
The link shown above reroutes to "http://www.avid.com/US/resources/digi-orientation" which is like dropping a kid off at Grand Central Station and telling him to find his way to Chicago (tells you how much confidence I have in my abilities, lol)...
When I reinstall PT LE 8, the only install options I'm given are shown here
http://i136.photobucket.com/albums/q...alloptions.jpg
I've installed the 8.0.4 update and the CS2 update. Running Mac OSX 10.5.8 with an MBox 2.
The USB light comes on and the MIDI Out 2 light under it blinks when I start Pro Tools and my tracks play through the monitors running from my MBox 2 monitor outs through the Command 8 but that's it.
Under "Setup > Peripherals" I have the following options and settings:
Synchronization
- MTC Reader and Generator
- MTC Reader Port : "Any"
- MTC Generator Port : "None"
Machine Control
- MIDI Machine Control (Master)
-[checked] Enable : "Command8, Port 1" - ID "127" - Preroll "90" Frames
-MIDI Machine Control Remote (Slave)
-[not checked] Enable : ID "127"
MIDI Controllers
- #1 Type : "Command8" - Receive From : "Cmnd8,Prt 1" - Send To : "Cmnd8,Prt2" - # Ch's : "8"
Ethernet Controllers
Satellites
I can also open the "Digidesign CoreAudio Manager" but the window shows the following:
Digidesign HW : Unsupported Device
Status : Not Connected (HW not found)
Channels : N/A
Attached Clients : 0
Buffer Size : 512
(Buttons at the Bottom)
"HW Setup..." (grayed out)
"Prefs..." Which brings up a window that shows:
- [checked] Hide manager if auto-launched by client
- [checked] Auto-quit manager when last client quits
- [unchecked] Use C|24 stereo routing (L/R to 1/3)
- (grayed out)[unchecked] Use XMON stereo routing (L/R t 1/5)
- (grayed out)[unchecked] Mirror analog outs 1 & 2 to digital outs (002/003)
"Connect" Which does nothing when clicked
"Quit" Which is the only button that works
Also, when I look in the Digidesign folder "Applications>Digidesign>Pro Tools>Controllers" I see a list of .bundle programs for 003, C24, Command8, Control24, Digi002, etc... but when I try to open the Command8.bundle, I get a Mac Dialog Window that says "There is no default application specified to open the document 'Command8.bundle"
That is about all the information I have. Please help.
  #23
Old 10-22-2010, 03:51 PM
Update:
It seems I have a difficult time reading online pdf manuals properly.
I was so worried about the fact that I didn't see the option to install the drivers during installation, that I didn't see the warning section on page 14 that says to use Port 1 for send and receive. That fixed it immediately.
Guh....
PC wont recognize my Mbox Pro. Please Help. Leonidas33 Pro Tools SE and Essential (Win) 1 04-17-2012 03:35 PM
PowerMac wont Recognize Mbox 2 pfrg999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-01-2011 09:59 PM
Pro tools LE 8 wont recognize mbox 2 khammon11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-11-2010 10:07 AM
OSX 10.5.5 wont recognize Oxygen 8, anyone? SurroundPro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-08-2009 11:53 AM
I really need help with this. PT wont recognize media drive greensombrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-19-2007 06:11 PM
