Old 04-15-2009, 05:56 AM
cleverwon cleverwon is offline
Default PT 8 Wont recognize COmmand 8
I upgraded to PT 8 from PT 7 on mac osx, and my command 8 isnt recognized at all. I uninstalled PT and reinstalled it and still nothing.
I was originally using it with PT 7 on a pc running Windows xp, but i switched to mac. it didnt work when i initially installed PT 7 before the upgrade either.
Edit/Delete Message
Old 04-15-2009, 08:48 AM
DigiTechSupt's Avatar
Default Re: PT 8 Wont recognize COmmand 8
Have you configured it properly in the Setups>Peripherals>MIDI Controllers window?
Avid Audio Tech Support
Support FAQ
Old 04-16-2009, 06:09 PM
um im not sure what to set. im new to mac and midi.
currently under setup - peripherals - midi controllers, everything is set to none.
I just set #1 to command 8, and i set receive from command 8 port 1 and send from command 8 port 3. im guessing here. but it still doesnt work.
please help!!!
Old 04-16-2009, 07:27 PM
i can get pt to play and stop using command 8 now, but the screen still says command 8 offline. and i get a pt popup that says it is unable to communicate with command i8.
Old 04-17-2009, 09:19 AM
Instructions for installation can be found in the Command|8 Guide, available here:
http://digidesign.com/index.cfm?navi...&categoryid=37
Support FAQ
Old 04-25-2009, 07:08 AM
Ok it works now!!! Thanks!
Old 05-05-2009, 09:20 PM
DUB13 DUB13 is offline
What are the correct settings in the Peripherals menu for PT8 Le & Command|8? [on Vista]
Since upgrading to PT8, I cant get the Command|8 to work [sits in offline mode]
I installed the Command|8 drivers etc when the option was available in the PT8 set-up before the install starts.
In the Peripherals, Command|8 shows up, but after it is set it still does not work. I have restarted PT and power cycled C8 etc but still no go.
Old 05-06-2009, 09:59 AM
I see you've posted the same question in two threads, so I'll ask the same question - how did you 'set it' exactly? Did you follow the instructions in the Command|8 Guide, linked above?
Support FAQ
Old 05-13-2009, 07:20 AM
Mauricevipb Mauricevipb is offline
Hi. Im having the same problem. my command 8 won't recognize pro tools 8 as well. Ive tried installing pt8 software twice and nothing happened. Im running a mac. OS X 10.5.6 What did you do to make it start running in pt8?
Old 05-13-2009, 11:37 AM
Probably followed the instructions:
Support FAQ
PC wont recognize my Mbox Pro. Please Help. Leonidas33 Pro Tools SE and Essential (Win) 1 04-17-2012 03:35 PM
PowerMac wont Recognize Mbox 2 pfrg999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-01-2011 09:59 PM
Pro tools LE 8 wont recognize mbox 2 khammon11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-11-2010 10:07 AM
OSX 10.5.5 wont recognize Oxygen 8, anyone? SurroundPro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-08-2009 11:53 AM
I really need help with this. PT wont recognize media drive greensombrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-19-2007 06:11 PM
