Old 01-09-2009, 04:38 AM
Petevsi Petevsi is offline
Default Re: Does the Pro-Control work with PT8 LE/HD - YES!
Hi kbruff
tried linking my home PT8 LE running on a HP laptop to the Procontrol with no joy , but it works okay with our C24.
Pete
MacPros, GBLabs Space, S1, Dock,
MTRX, Dante, Protools HDX, VoiceQ
www.vsi.tv
Old 01-09-2009, 06:40 AM
BlindState BlindState is offline
Hi kbruff
Pete
Pete, did you put the ProControl_M.bundle and ProControl.bundle files in this directory, or make sure they were there?
-->SystemDrive/Applications/Digidesign/Pro Tools/Controllers
Then after a reboot you should be able to go to
-->Setup/Peripherals/Ethernet Controllers
and it should be there?
This is just what I have learned on these forums from other members like: Pete Gates, drogan88, NewDave, DC2light etc etc. THANKS GUYS!
But, I am very interested in seeing this work before I shell out some cash loaf!
CBC
BlindState
Old 01-09-2009, 09:40 AM
satrackworks satrackworks is offline
Hi guys,
Having trouble here too on a Mac Quad 2.66mHz. Fresh install of Leopard 10.5.5 on a new drive. Pro Control Bundle seems to be in the right place but Pro Tools 8 can't see the Pro Control. PT 8 is working fine otherwise. (Well, there are a couple of plug in issues but that's another matter.)
Pro Tools 7.4 in Tiger is working fine with the Pro Control on the same machine. Any suggestions what I might try?
Thanks!
Steve
Old 01-12-2009, 04:36 PM
Asar Asar is offline
CBC
BlindState
blidnstate can you email me at iamasar (a) aol.com i have some questions about this
Old 01-13-2009, 01:36 AM
CBC
BlindState
Hi BlindState
I was running PT8 on my home HP Vista laptop (works very well, once you get the setup right BTW) so the file paths are different, but there was no legacy controllers on it. It saw our C24s okay but not the Procontrol sadly.
Pete
www.vsi.tv
  #16
Old 01-15-2009, 08:23 PM
DC2light DC2light is offline
So any luck yet on a Mactell?
Cheers,
Señior Light
Full Bandwidth 24/7
  #17
Old 01-16-2009, 02:07 AM
Pete Gates Pete Gates is offline
I was quoted earlier in the thread. I never did manage to get it to work on my quad 3.0GHz or my octal 3.2GHz machines though. I suspect Digi blocked this from working some time ago.
Pete
  #18
Old 01-17-2009, 12:48 AM
Well in 7.4.xx LE no problem, working fine. I alternate between two machines and 2 setups (LE, HD) and need the ProCon to work on both.
Cheers,
Señior Light
Full Bandwidth 24/7
  #19
Old 01-17-2009, 11:37 AM
WorldStudios WorldStudios is offline
I run 8.0 on a 4x2.66 MacIntel. 16 faders of ProControl works as well as it ever did.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #20
Old 03-01-2009, 01:07 PM
sdmike sdmike is offline
Johan, that's excellent. Can you provide any more details on what you had to do to get it to work? Any configuration tricks? I'm on a 4x2.8 Mac Intel with PT8 LE and DV Toolkit. I'm looking at buying a used PC MC100 but want to be sure I'll be able to get it up and running.
Thanks!
my Control 24 will not work with HD10 phatbeatstudio ICON & C|24 1 01-17-2012 11:43 AM
Will control surfaces work for PT 11? silverstein Artist Series 1 11-22-2011 10:17 AM
Control 24 & PT LE, only some buttons work! weezy ICON & C|24 2 08-29-2005 08:15 AM
Will Protools LE work with a Pro-Control? drogan88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-27-2004 04:49 PM
What control surfaces will work in PT6? Matt Stutter Pro Tools TDM Systems (Mac) 1 01-28-2003 11:17 AM
