Old 12-30-2008, 03:34 PM
kbruff kbruff is offline
Default Does the Pro-Control work with PT8 LE/HD
Does the Pro-Control work with ProTools 8 LE and HD under MAC-Intel OS 10.5.5?
Old 01-01-2009, 07:14 AM
Petevsi Petevsi is offline
Default Re: Does the Pro-Control work with PT8 LE/HD
all works fine with HD
Pete
Old 01-01-2009, 07:48 AM
Pete
Thanks for your reply, but does it work with LE 8 etc.
Old 01-01-2009, 01:47 PM
vudoo vudoo is offline
Pete,
How do you like your C24 compare to the Procontrol. I was offered a PC + fader and Edit pack. Still undecided wether to get a C24 or the PC. I work mostly out of my home studio wich i just upgraded to 5.1 and Dangerous Monitor ST-SR. Thanks.
Old 01-02-2009, 01:19 AM
Originally Posted by vudoo View Post
Pete,
Hi Vudoo
I have to say (and I will get shot down for this) for 5.1 the PC + edit pack is excellent. The layout and matrix in the main section is so much quicker to use and the faders and joysticks feel so much better. The monitor section sucks but if you are using the ST-SR then that shouldn't bother you. On the down side the PC is old and I don't know how long Digi will keep supporting them in software releases. Don't get me wrong the C24 is a great controller and the monitor section is way better for 5.1 but I still love the PC, it just seems more intuitive to use.
Hope this helps
Pete
MacPros, GBLabs Space, S1, Dock,
MTRX, Dante, Protools HDX, VoiceQ
www.vsi.tv
Old 01-02-2009, 01:26 AM
Hi Kbuff
sorry we don't have any LE systems so I can not check. Not sure it is. Best ask Digi.
Pete
www.vsi.tv
Old 01-02-2009, 06:02 AM
Hi Kbuff
Pete
Thank you.
Old 01-03-2009, 11:08 AM
tvent tvent is offline
I didn't think the Pro Control worked with LE systems at all?
Old 01-03-2009, 10:13 PM
D3lta D3lta is offline
The Pro Control has never worked with LE
Old 01-07-2009, 01:38 PM
BlindState BlindState is offline
Lightbulb Re: Does the Pro-Control work with PT8 LE/HD - YES!
Hi. I'm a noob and I am getting either a used PC or a Control 24, and I was wondering the same thing "will the PC work with LE?" The answer I found on the digi site says no, but according to many post here, as well as someone I know, as long as you have the controller profile files ProControl_M.bundle and ProControl.bundle in the proper folder it will work!. Check out these threads :
http://duc.digidesign.com/showthread...=procontrol+le http://duc.digidesign.com/showthread...ght=procontrol http://duc.digidesign.com/showthread...ght=procontrol http://duc.digidesign.com/showthread...ght=procontrol http://duc.digidesign.com/showthread...ght=procontrol http://duc.digidesign.com/showthread...ght=procontrol http://duc.digidesign.com/showthread...ght=procontrol
You should find it all in there.
CBC
BlindState
p.s. In one post someone mentioned having trouble on an Intel based Mac, but when they went back to PPC Mac it worked again. I guess ymmv.
my Control 24 will not work with HD10 phatbeatstudio ICON & C|24 1 01-17-2012 11:43 AM
Will control surfaces work for PT 11? silverstein Artist Series 1 11-22-2011 10:17 AM
Control 24 & PT LE, only some buttons work! weezy ICON & C|24 2 08-29-2005 08:15 AM
Will Protools LE work with a Pro-Control? drogan88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-27-2004 04:49 PM
What control surfaces will work in PT6? Matt Stutter Pro Tools TDM Systems (Mac) 1 01-28-2003 11:17 AM
