  #21
Old 03-17-2009, 10:24 AM
DigiTechSupt's Avatar
Default Re: C8 not recognised in PT8
Originally Posted by zeze View Post
I'm having problems too with my C|8 connected to a PPC G5 (Leopard 10.5.6 - PTLE 8cs2)
when I turn on C|8 it often doesn't make the usual startup routine, the faders do not move and the display act way irregular, almost not visible,
and obviously PTLE do not recognise it;
I try to shut off and turn on several times hoping it will wake normal state,
but not always this works;
I've read in this topic of this 'repair option' in the PT installer, which I cannot find anywhere into the Mac installer for PTLE 8;
can you please explain precisely how to do this operation?
thanks_
This sounds like a defective unit. You don't have a 'repair' option because you're not on Windows, so it's unnecessary. If you do not have the C|8 connected and it's still not going through it's startup routine, you should contact your dealer or tech support for information on how to get it fixed.
Avid Audio Tech Support
Support FAQ
  #22
Old 03-17-2009, 10:29 AM
Everyone else may want to look through these possible solutions:
http://www.digidesign.com/index.cfm?...&categoryid=34
You can also get the latest firmware here:
http://digidesign.com/index.cfm?navi...36&nStartAt=31
Support FAQ
  #23
Old 03-17-2009, 12:38 PM
MIXING GUY MIXING GUY is offline
I updated my Firmware already, but When I was in PT 7.4.2 it was working, until I upgraded. I have sessions to mix and It's taking more time to mix without my Command 8. Any ideas on why this is happening? I see the command 8 in my Perhipherals, but it doesn't sync up on the send and receive part. Also, I'm on a Mac Pro not a PC with Windows XP I'm using the latest Leopord OS
  #24
Old 03-17-2009, 01:29 PM
Can you explain what you mean by this?
Support FAQ
  #25
Old 03-17-2009, 05:03 PM
Ok Guys I figured it out. First thank you to the Digi Tech Support for giving it a shot!!!! I appreciate the help Sir or Ma'am. Ok all i did was go into the pheriperials and then midi controllers and on the 1st menu I went down to Command 8 and for the send and recieve I put it on The Command 8 port 1 on both menus and it syncd up!!!! there you have it!!! Take care guys and Happy Mixing
P.S. I forgot to mention that I upgraded to ProTools 8 cs2 on my Mac Pro on OSX 10.5.6
  #26
Old 05-05-2009, 09:19 PM
DUB13 DUB13 is offline
What are the correct settings in the Peripherals menu for PT8 Le & Command|8? [on Vista]
Since upgrading to PT8, I cant get the Command|8 to work [sits in offline mode]
I installed the Command|8 drivers etc when the option was available in the PT8 set-up before the install starts.
In the Peripherals, Command|8 shows up, but after it is set it still does not work. I have restarted PT and power cycled C8 etc but still no go.
  #27
Old 05-06-2009, 09:57 AM
How have you 'set it' exactly? Did you follow the instructions in the Command|8 Guide?
Support FAQ
  #28
Old 05-06-2009, 10:47 AM
Yes...i have followed the guide
Is PT8 any different from 7.4? As I had the command|8 working fine before upgrading..
For some reason the play and stop works, but it still says offline and nothing else is functioning
I also get the error msg pop-up
  #29
Old 05-09-2009, 08:36 AM
Still cant get this working
The Command|8 only works with the play and stop buttons
And still says offline on the display
What should the peripheral settings read in PT8?
Any info would be appreciated
  #30
Old 05-20-2009, 11:38 AM
That's covered in the Guide, linked above.
What are YOUR settings in Peripherals?
Support FAQ
003 Not recognised by PT9 TLK Tom Pro Tools 9 3 05-02-2011 01:18 PM
D24+888/24 not recognised with XP in PT5.3.1 ultrarelou Pro Tools TDM Systems (Win) 4 06-30-2004 06:08 AM
001 NOT RECOGNISED IN WIN XP Paul T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-10-2003 02:45 AM
001 not recognised in win xp Paul T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-17-2002 06:05 PM
help 888/16 bit is not recognised with 5.1.1 digigirly Pro Tools TDM Systems (Mac) 4 08-28-2001 01:49 PM
