Trouble with Mix Plus voice count...
hey all, having some issues here:
helping a friend put together his system AND have hit a snag. he has a Mix Plus system (1 core and 3 farms) tdm. he was able to get 64 voices out of this system (and still can) he just acquired another core and 3 more farms. he was under the impression that this would allow him to run more than 64 voices. is this correct?? if so, im not able to do that with this system. we can use each core on its own with the other out of the system, but not together for more voices. heres the specs: G5 1.6 Single processor Running Panther 2 gigs of ram 7 slot PCI Magma Chasis 2 cores and 3 farms installed as of today but Monday WIll install 2 more farms any ideas about whats causing the voices to stay at 64? any help is much appreciated!! thanks! c
CHUCKNKD [url=www.myspace.com/chuckbutlermusic[/url] |
Re: Trouble with Mix Plus voice count...
64 is the largest number of voices you can have on a Mix system.
Adding more cards will increase the number of plug ins he can run simultaneously, however, there is a limit of 7 such cards. If you're now looking to sell one of the PCI cards for a reasonable price, I might be interested. Hope I helped! |
Am I understanding this correctly that he's trying to add another core card to a mix system to ADD 64 more voices? If that's the case, then it won't work. Only the first core card actually inits as a core, every other card will init as a mix farm card. He could obviously use a second computer and slave the two systems together to run more voices but that would be a bit cumbersome.
thanks for the replies guys! that answers the questions.
so if it sees the 2nd core as a farm, is there a diff in dsp power between the two? which would be the more powerful? thanks again! c
There's no differnce between a Core being seen as a farm, and a farm itself.
Also, check the compatibility docs, you won't be able to use all the cards, there is a limit of 7. Also, if you're interested, please write down my email address? I'm gonna remove it tomorrow now that you're reading this thread. Cool! |
So do I understand correctly he is running a chassis with G5 without a problem? G5 are not supported and should not work with MIX system. Although there have been rumors that some people have them in G5's...
No issues at all. The CPU goes well, the PCI bus also. I'm using a model (EARLY 2005) that has the PCI slot, not the PCI-X.. a friend of mine is using the same system on a Dual 2,5 Ghz with the PCI-X without problems. I'm still opening the same sessions that I opened months ago on my old G4 and the system goes well and is also much more pleasant to use. My old MDD G4 was terrible for the noise!
Digidesign said a lot of things about G5 and Mix but Apple demonstrates that the PCI-X and PCI of the old PPC G5 worked with 3,3V PCI cards and Digi admitted that Mix Core & Farms were 3.3V so... make the sum! |
How do I free up voice count in HDX | Weird Audio | Pro Tools HDX & HD Native Systems (Mac) | 20 | 11-22-2012 10:04 PM |
How to free up voice count , is it possible | Weird Audio | macOS | 3 | 10-30-2012 05:39 PM |
HD7 voice count | Raoul23 | Pro Tools TDM Systems (Win) | 7 | 11-13-2011 01:08 AM |
PT HD voice count | garnoil | Pro Tools TDM Systems (Mac) | 10 | 11-05-2008 07:47 PM |
Voice count for PT NT|24 Mix | Euphony Sound | Pro Tools TDM Systems (Win) | 1 | 04-21-1999 10:26 AM |
