Strange session state - display frozen, play/record strange
Somehow I've got my session in a strange state. When I select play from the transport I get audio but the display shows nothing. When I select stop on the transport, the levels appear, but are then frozen. Selecting record does nothing. It won't respond to my command-8 at all. Selecting a region of audio causes the audio to start playing, even if I had previously been stopped. Other sessions behave properly, so whatever has happened, it's unique to this particular session. I believe it began when I hit play while the session was still loading. Has anyone seen this? I couldn't find anything in the user forum on this, but I'm having trouble even describing the problem, so searching for it is tricky at best. |
Re: Strange session state - display frozen, play/record strange
Hmm... sounds strange indeed.
It's only THIS session ? PT displays fine on other sessions after this one has been played ? Have you tried creating a new, blank session, and importing all session data, including Tempo Map, from the old session ?
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Hi David, Sorry for the very long delay in replying. I ended up exporting the audio files and otherwise starting over from scratch. I'll go back to the original broken session and try what you suggest. It doesn't appear that many people have hit this, so hopefully I'll never see it again. Nevertheless, it would be good to have a workaround if it does. Thanks for your response. |
Strange issue with button PLAY | tristan klein | macOS | 113 | 02-03-2015 04:33 PM |
strange display issue MC Mix (Euphonix) | nstu | Artist Series | 0 | 02-18-2012 06:03 AM |
Back & Play strange behaviour in record...? | karegranat | Pro Tools TDM Systems (Mac) | 0 | 10-15-2011 09:14 AM |
Strange Play Problem. | Rabre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-16-2005 07:52 PM |
Strange numbers in my play list?... | monkey | Pro Tools TDM Systems (Mac) | 4 | 08-11-2001 09:33 AM |
