Old 01-06-2007, 06:36 PM
on tilt on tilt is offline
Default blank gray screen
i install LE 7.0 a few months ago. i used it with no problem for a while. after about 2 weeks of not using it, i pulled up one of my files and one of the tracks was missing. since i'm relatively new to this, i assumed that i had done something wrong. since then, i've been really busy and haven't even turned on the computer in about 2 months. now, when i open up PT and try to open a session (whether previous or new) all i get is a blank gray window with the session title in the header bar. i'm not sure where to go from here. this computer is not connected to the internet, i don't use it for anything other than recording. no one else has used the computer but me. i'm just kinda stuck.
any suggestions
Old 01-06-2007, 09:51 PM
Marty Bampot Marty Bampot is offline
Default Re: blank gray screen
If you had no error dialogs on startup, it may be just that your Edit and Mix windows have become minimised. On the menu try clicking on Window and then Edit to see if it pops open.
Otherwise, do the Delete DAE & Pro Tools Preferences process as described in the General Troubleshooting message on this forum.
Cheers,
Marty.
Intel D945PSN, P4D 830 3GHz, 2GB RAM, 200 + 320GB SATA, NV6200TC,
Delta-66, PTMP 7.4cs7, Soundcraft Compact10, Roland DS-30A, Rode NT2
Old 01-07-2007, 10:47 AM
thanks,
no error messages and no screens minimized. all windows are just blank gray.
i'll try your other suggestion though. thanks again
any other suggestions are welcome as well.
Old 01-07-2007, 11:21 AM
JMS40 JMS40 is offline
Can you access any of the PT menu's?
If so, does the Track List show any audio files associated with the session?
Old 01-09-2007, 03:16 PM
when the main window for PT opens the menus available in the upper left hand corner are there and usable. when any other window is opened, it shows the session title in the header bar, but the rest of the window remains blank and unusable. doesn't matter if it's a previously saved session or starting a brand new session.
Old 01-09-2007, 03:40 PM
zombie69 zombie69 is offline
Can you post a link to a screen shot so we can see what you are describing?
I wear the pants. (My wife picks them out)
Gray area on Edit Screen mrgroovy Pro Tools 10 3 04-04-2013 11:36 PM
Problem installing PT LE on XP: small gray screen XanderMoser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 02-06-2013 04:00 AM
Pro Tools 10 opens to gray screen... Jimibrix Windows 4 01-15-2012 06:36 PM
Waves Gray screen in a testing leopard system? TCDet Pro Tools TDM Systems (Mac) 2 04-15-2008 12:00 AM
gray screen with atto card - help RDunn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2002 05:53 AM
