Chipset Compatibility
Does anyone know if the Intel 848P chipset has any issues with Pro tools or the 002r? Any info would be awesome. Thanks
Re: Chipset Compatibility
This isn't the best place to find that answer, being a Mac forum and all...Here's what Digi says.
"Chipset Requirements The following chipsets are recommended for best performance with Intel P4 processors: * Intel 850/850e * Intel 845/845e/845pe * Intel 865pe/875p Not tested: * Intel 9.x series" As long as you have a P4 at 2GHz+ you should be good. Unless that jump from the 845's to 850's is more significant than I can imagine. But that's why I use a Mac. Good luck. MR
Learn to listen. Listen to learn. |
CPU/Chipset compatibility | orlandorecording.com | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-21-2007 08:23 AM |
More Chipset Compatibility with PT 7??? | powderhound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-07-2005 12:56 PM |
Chipset Compatibility | jalpunk | General Discussion | 1 | 01-25-2005 08:51 PM |
Chipset Compatibility | jalpunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2005 04:44 PM |
Chipset Compatibility | dsjones93 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-09-2003 11:28 AM |
