Old 01-21-2020, 09:26 AM
the.engineer the.engineer is offline
Default Catalina on Mac Pro 5,1
Has anyone tried it?
Clearly we're entering hackintosh territory here so nothing will be supported BUT I'm interested to see if it works.
I'm kinda liking the look of Pro Tools 2020 but don't want to shell out for a new computer right now.
There's a patcher by DosDude1 that makes it pretty straight forward.
Thoughts?
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 01-21-2020, 10:44 AM
Default Re: Catalina on Mac Pro 5,1
Pretty much same requirements than Mojave (as in Metal compatile GPU) and obviously the Catalina requirement of 64-bit only software
Old 01-21-2020, 10:49 AM
Thanks JFreak. That makes sense. My 5,1 is already running Mojave very well.
I’m hoping someone out there has done it and is running pro tools!
James Welch
Old 01-21-2020, 10:51 AM
Obviously Apple may make it hard for someone using unsupported hardware, but it is nothing new. I have installed Mojave for god knows how many unsupported hardware, and granted it is some more work you can build a working configuration even if Apple said no.
Old 01-21-2020, 12:29 PM
That’s great to hear.
James Welch
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Mojave 10.14.5 | Pro Tools Ultimate 2019.5 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
James Welch
Old 01-21-2020, 12:30 PM
Sure.
Let me just state the obvious: unsupported means use at your own risk
Old 01-22-2020, 09:07 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Thoughts?
ProTools 2020 should still work under OS 10.14,x
Or did I miss something?
Old 01-22-2020, 09:08 AM
compatibility info here. bookmarki it
Old 01-22-2020, 12:42 PM
I don’t think you missed anything. I’m just intrigued by 64 bit only.
James Welch
Old 01-23-2020, 12:40 PM
Funnily enough the only app on my entire system that has a 32 bit component is...Pro Tools
James Welch
HDX in new Mac Pro/Catalina rourketown Pro Tools 2019 11 08-24-2020 03:40 AM
PT and Catalina gub macOS 3 12-21-2019 12:48 AM
Catalina cqd Pro Tools 2019 10 10-09-2019 01:37 PM
Catalina Ryan Young Pro Tools 2019 6 06-06-2019 10:20 PM
