Old 10-30-2010, 10:29 PM
nwilson@hns.com nwilson@hns.com is offline
Default Heat vs VCC
Demo'ing both. Both are nice. My take is they are different animals, but with all things considered I'm leaning a bit more to Slate VCC.
I like Heat (being a PTHD user) as it's built-in (strip at the top of the channel and don't have to mess with RTAS plug-ins), and simple to use. Sounds good. I'm a fan of Dave Hill's products, and HEAT does add a nice touch of color, punch, etc.. It's maybe more subtle then the VCC, and maybe in some ways better sounding as seems a little more transparent then VCC (adds a nice bit of color without changing the mix as much as VCC does), but then on the other hand I tend think VCC sounds more like a finished record in a good way when it's switched in.
I also like the Slate for having more options and a clear target on summing / console emulation. Tracks are a bit more present (in your face sounding), maybe a little compressed, but in a good way. Makes me think it sounds more like a record (part way toward mastered) then HEAT. Also seems to change the stereo image a little bit, as some things sound more in the middle. The user interface is a bit more work with more options and controls at the channel level, over HEAT's simple controls. There is some beauty to HEAT's less options allowing the focus to go more on the music and other tasks, then fiddling with options.
I'm still wired for stems out through an 8816 with Hammer and Manley Vari-Mu on the mix bus, so it's not really a stand alone test. Been too busy to test all ITB yet.
My demo is running out, and wish the VCC was a final product to hear what it will be. Wondering if other PTHD's people came to conclusions on what to buy and what you based your decisions on. Thanks... Neil
Old 10-31-2010, 12:20 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Heat vs VCC
So you managed to run VCC without it constantly crashing your system!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-31-2010, 06:35 AM
boogiemotel boogiemotel is offline
VCC solid here
kicks ass over heat i personally think ..
Old 10-31-2010, 05:00 PM
Oli P Oli P is offline
VCC is solid here too....but I really love HEAT and VCC together.
HEAT gives me the tape saturation, and VCC frames it in a more console like fashion.
I don't see them as in competition to each other...more complementing.
HEAT is also much less subtle, so it makes a much better coloring tool...VCC just gives that old console feeling most of us find pleasing and familiar.
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
Old 10-31-2010, 05:16 PM
Fidelis Fidelis is offline
Originally Posted by crizdee View Post
Chris
VCC running rock solid here! Not a single crash. Pt HD3 acell v. 8.0.4 on 10.5.8
didn't try heat yet.
http://www.ricardomosca.com
Intel Mac Pro 12 core 3.33 GHz, 20GB RAM, OSX 10.10.5, PT HDX, PT 12.8, SSL 4040G+, tons of outboard
Mac Book Pro 2.4Ghz Duo, 4GB RAM, OSX 10.10.5, PT Vanilla 12.8
Old 10-31-2010, 08:39 PM
HearInc HearInc is offline
I went for VCC based on price and flexibility. Very happy with my decision.
I've got some funky graphics things going on with VCC on my second monitor, but other than than, it's been solid for me.
Brian Steckler, Producer
Old 10-31-2010, 09:15 PM
roberts roberts is offline
Chris
Get rid of your Duende and your issues will go away
Old 10-31-2010, 09:23 PM
WernerF WernerF is offline
Get both of them. They work great together. I have to dissagree with the OP though about HEAT being more subtle than VCC. It's just the opposite. You can get some really crunchy distortion out of HEAT that is not really possible to do with VCC. All you have to do is push each one to it's limits and it will be quite obvious, provided the source material is hot enough.
Old 11-01-2010, 12:10 AM
Eric Lambert's Avatar
Chris
Shouldn't an explanation follow a post as dramatic and accusatory as that? Please explain this crash epidemic for those of us that don't know anything about it.
Old 11-01-2010, 01:08 AM
crizdee's Avatar
Every time i try it in a session it last 5-10 minutes and freezes.
I persevered with it and kept trying it and i all i got was crashes.
i'll upload a video later
Chris
Producer, Engineer,
www.ukmastering.com
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Heat? or Something Like it? Numi Pro Tools 9 24 06-11-2011 06:13 PM
Something like Heat for LE? DonaldM Tips & Tricks 15 02-04-2011 02:20 PM
Can I use heat in PT HD 9 with a 003? evertonlouvize Pro Tools 9 11 01-21-2011 09:19 PM
HEAT and PT 9 non-HD chicken Pro Tools 9 1 11-10-2010 06:43 AM
