Digibase bug or limitation?
I'm noticing that Digibase shows me nested folders, but when I double click on those folders, it shows them as being empty. If I reveal that folder in the Finder, the files are there.
Is there a limit to how far Digibase goes down to find files? I'm running the most recent Leopard (10.5.8) on a duo quad core. PT 8.0.3 HD. I have removed all digidesign databases from mounted drives and toss out those inside: Macintosh Hard Drive/Library/Application support/Digidesign/Databases/Unicode/Volumes I emptied the trash and rebooted. Thanks, Jim |
Re: Digibase bug or limitation?
That doesn't sound good. What happens if you right click on the folder and choose "Update database for selected" before opening it?
Cheers, Paul Vercellotti Avid Engineering |
Instead of right clicking (Control clicking doesn't bring any menu up), I selected the folder and chose Update database for selected. That did not resolve this issue. I then confirmed that there were files in that folder (in the Finder). There were.
Thanks for the hasty reply.... Love to get this working. Let me know if I can help. Jim |
Bump.
Any word on fixing this? thanks, Jim |
Is anyone else experiencing problems with Digibase not showing files in nested folders?
JIM |
This problem has seemed to have resolved itself. I had to do some troubleshooting yesterday and made some changes. If you are having this issue, the things that I did recently were:
Toss all prefs, database files with that wonderful tool that does it automatically. Upgraded to 8.0.3cs1 good luck.... Jim |
Does that folders have a custom icon assigned?
Try to trash invisible .DS_Store file inside it.
PT 12.8.0 Mac OS X 10.9.5 MacPro2,1 Quad-Core Intel Xeon 16GB RAM |
I think this may have been the core of your problem.. that app is worth it's weight in gold It is so difficult to manually do all that, particularly if you have a lot of drives. Cures a lot of ales.. ff
ALE is one of our treasured brothers....
AIL is something in need of a cure. just saying (totally clowning here)
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Hi
I also found that digibase sometimes does not find all files. I had some situations when I had to search with spotlight. Spotlight finds and digibase not! Trashing prefs did not help This is also under 7.4, where I keep on working with. Ale ------------------- to my treasured brother studiojimy I did not know that you are so famous in sweden. Just look at this video. Who does not know how studiojimy looks like, will not understand http://en.tackfilm.se/?id=1265210364707RA62 Have fun!!!!!!
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
Is this a windows limitation ? | jeam25 | Windows | 6 | 02-25-2013 11:53 AM |
limitation to HD on protools 7? | newonthebench | Pro Tools TDM Systems (Mac) | 0 | 07-30-2010 06:12 AM |
Ram Limitation? | jc7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-20-2009 10:50 AM |
32 Track Limitation | protoolsjimmy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-07-2007 12:19 PM |
Ram limitation. HELP !! | Allan Speers | Digidesign Hardware & Software | 4 | 12-10-2002 01:43 PM |
