Old 05-25-2007, 11:28 AM
manicdown manicdown is offline
Default Waves SSL versus Duende for LE
Has anyone used both? Aside from the obvious processor implications, what's the difference if any in sound?
D
Old 05-25-2007, 12:03 PM
Forum Member LE Forum Member LE is offline
Default Re: Waves SSL versus Duende for LE
Both are good but they are different as they should be since they are based on different SSL units.
Biggest thing to consider is the Waves SSL works with LE the Duende may need some help.
People have gotten inconsistent results with FW LE systems and FW drives.
Some HD guys had issues as well.
A couple of people added a dedicated FW bus for the Duende and it helped.
Also the Waves SSL seems to use less CPU than the Gold bundle??
I think it was over at GearSlutz that some comparisons were also done so you might want to search there.
For me I was impressed with the Duende but didn't see it being worth the potential problems so I went with the Waves and that was somewhere round January and I havew been really happy with it.
Old 05-25-2007, 12:55 PM
Music to my ears since Waves is half the price
Surprised to hear that it hasn't run so smooth on LE because that is not the story I got from the SSL rep...BUT, that's exactly why I posted on here. Get the REAL deal! He was saying that one of the benefits is that because it has it's own engine, it doesn't use your computer's processor. Are the problems just "keeping up" issues? He also said that with Duende, you can choose between SSL G or E.
Thanks so much for replying...really appreciate it.
D
Old 05-25-2007, 05:14 PM
The two problematic variables with both the Duende and the Liquid Mix is that they are wrapped and use a lot of FW bandwidth and the 002/003/MBoxPro use a lot of FW bandwidth.
That pretty much means that you need a Mac with a dedicated FW bus for each to get the proper reliabiity.
Then we also have the aspect of FW drives in the equation.
No doubt the Duende takes the load off your system but you still have to deal with the FW.
It's not that you can't get one running it's more wether you want to deal with what it may take to do so.
Almost to the degree that if I would have been dead set on the Duende I would have changed my host application to something more VST friendly and not locked into the hardware like PT LE.
Also remember that the Waves is based on the SSL-4000E and G series while the Duende is ported from the C-200E and G series so even if they were 100% identical to the original they would still sound different.
Old 05-26-2007, 11:27 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I've been starting every mix lately with either a Waves E-channel or Vintage 4 band eq. across every single track.
This is truly a revolution!
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 05-26-2007, 01:58 PM
peppertree peppertree is offline
In an online shootout of an early rev of the Duende bus compressor I preferred it to the Waves version. However, for the price difference, going Waves and upgrading to a Mac Pro makes a whole lot of sense in the near term. Should LE add Automatic Delay Compensation and the Duende come down under a grand and add a few plugs, the balance would shift toward Duende I think.
`My name is Pro Tools HD, King of Kings:
Look on my works, ye mighty, and despair!'
Nothing beside remains. Round the decay
Of that colossal wreck, boundless and bare,
The lone and native DAWs stretch far away.
Waves NLS versus Slate VCC musicman691 AAX Plug-ins 44 12-02-2013 05:45 PM
Duende Native VS Waves SSL Bundle Becharax Pro Tools 10 3 06-22-2012 08:44 AM
Waves SSL vs. Duende Richard Conrad Pro Tools TDM Systems (Mac) 14 07-12-2006 04:00 PM
Waves L1 versus L2? ebshen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-11-2002 09:58 PM
Waves L2 versus L1 Ray Fabi Tips & Tricks 5 02-20-2001 05:20 AM
