Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 04-11-2016, 02:14 AM
rpl16a rpl16a is offline
Default Odd issue. Any ideas please?
Hi guys & girls.
I wonder if anyone would be able to help me with an issue I have with my Command 8.
I have owned my Command 8 control surface for 5 years from new now and it has been kept in A1 condition in a non smoking environment.
I use the control surface every day in my semi pro home studio with the latest pro tools and it has never let me down, apart from its curious behaviour when I switch it on (this happens when my computer is off and the command 8 is totally disconnected from my computer. No USB, no audio leads etc).
The issue stated also occurs when the USB is connected to my computer.
At first, I though it may be the faders need replacing, or it was a static build up. I have replaced the faders, (not cheap!). This still didn't sort the issue.
I can only assume that the firmware may need downgrading and then upgrading again or the main chip need re-writing.
Alternatively, dose anyone know of a 'Hard Reset' you can do to the Command 8, that would re-set all parameters as if it was a new, never before used desk. (I'm thinking it could be a MIDI transmission issue conflicting with another device. Maybe it's written something into the memory of the Command 8). Just grasping at ideas.
Each time I power up the unit, different faders are effected.
Any ideas or information would be greatly appreciated.
Thank you.
VIDEO : https://youtu.be/YZDwmYWNoaw
Using internal bus in PTHDX causing timing issue-Any ideas? songwritersoul Pro Tools 11 8 05-26-2015 10:27 AM
Master Fader issue, any ideas? jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-28-2013 05:44 AM
Control 24 Input gain issue: Any ideas? popps Pro Tools TDM Systems (Mac) 4 03-07-2006 08:22 AM
Any ideas or experience on sync issue neekolas Pro Tools M-Powered (Win) 0 06-30-2005 11:22 PM
New Freezing Issue - Ideas? PTLE6.4 theMeanTeam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-15-2004 12:55 AM
