Old 06-02-2012, 08:14 PM
francois's Avatar
francois francois is offline
Default Icon monitoring
I'm getting a D-command this month replacing my Procontrol.
I'm monitoring thru a Coleman TB4 bypassing the Procontrol and wondering if
the Xmon is going to be on Par with it (Coleman) thus getting rid of the
Coleman
Any insight ?
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 06-02-2012, 08:23 PM
Drew Mazurek's Avatar
Default Re: Icon monitoring
Love my X-Mon.
If you plan to use the Auto Talkback and/or Auto Listen mic features like I do, you'll need to use it.
www.drewmazurek.com
Old 06-04-2012, 02:30 PM
Hanswurstlsepp Hanswurstlsepp is offline
Coleman
Any insight ?
I would recommend to get rid of the TB4 and instead use d-commands Monitor section together with the X-Mon. Makes your life much easier
Also SIP/AFL/PFL works perfectly fine by doing that.
d-command & x-mon covers almost everything I need. The only gadget I added is a custom built monitor switcher for more monitor speakers as the d-command got only 2 left if one uses the XMon Alt Meter patch which lets you connect your (RTW) level meter to the Alt-Output.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 06-05-2012, 03:00 PM
francois's Avatar
Thanks for the positive responses .
I'll try to do a quick A/B on the 2
I want to make sure my chain is still pristine when I do some mastering
Old 02-18-2013, 02:57 PM
Squint Music Squint Music is offline
Hey Francois,
Did you ever do this test? I'd be interested to know the results. I'm thinking of getting an Avocet to replace the Xmon if it is better.
Old 02-21-2013, 09:35 AM
francois's Avatar
I never bothered.The imaging and quality is fine with the Xmon.
Francois
Old 02-22-2013, 06:58 AM
[email protected] info@npp.co.uk is offline
No AFL/PFL without XMon
Old 02-22-2013, 06:59 AM
Not entirely true. You can still do it, but you lose the auto switching that the X Mon does.
If you use the "AFL Mutes" option in the I/O setup you can get pretty close to what the xmon does.
www.drewmazurek.com
Icon D-Command Cue Monitoring Issues elankf1 ICON & C|24 19 11-27-2017 01:33 PM
Direct Monitoring VS PT Monitoring therecordinghouse macOS 5 11-23-2013 05:18 PM
Record monitoring level different from Playback monitoring level. sonicflwr macOS 1 03-09-2012 10:05 AM
Monitoring through Rosetta vs Monitoring through 003 Rob0214 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2010 03:02 AM
one ? re: ICON... can it be used without a PT rig? MixerGuy ICON & C|24 2 10-10-2006 09:10 AM
