Old 02-20-2002, 05:57 PM
sounddesigner sounddesigner is offline
Default NEW Dual 1 GIG G4 Mix system NOT WORKING
I Have Done all the steps that digi said to do with the dual system. The App (PT 5.1.3)
Will not open. I get error #2 And or it crashes?????? Anybody have a thought? [img]images/icons/shocked.gif[/img] [img]images/icons/confused.gif[/img]
Old 02-20-2002, 05:59 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
Default Re: NEW Dual 1 GIG G4 Mix system NOT WORKING
I would wait until Digi qualifies it.
Old 02-20-2002, 07:42 PM
BradLyons BradLyons is offline
I'm assuming so, but you've disabled the second processor, correct? I'm not aware if we've tested any dual 1ghz machines with PT or not.... I'll check into this tomorrow and see what kind of issues we may have over here. Is this happening constantly or just every once in awhile?
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 02-21-2002, 01:18 AM
Florian Florian is offline
my dual 1 gi runs perfectly, PT 5.1 though.
mixplus+1dsp
scsi adaptec 2940u2w works for audio playback and hotswap compatibility only, but i use a 100 gig wd ata for recording sessions now .
also, 2nd processor does work, gives pci bus error once in a while but not unbearable...
if its disabled, the mac and pt run great.
www.florianammon.com
Old 02-21-2002, 06:10 AM
ChaplainPC ChaplainPC is offline
Florian,
How do you like the WD 100 GB drive? How is the noise and heart? Is the drive fast enough?
Thanks,
Pete
Old 02-21-2002, 06:58 AM
advid advid is offline
Is there anyone using Magma Extension bay with the new G4/933 or G4 Dual 1G ?
Old 02-21-2002, 07:44 AM
uno1234 uno1234 is offline
how do you know it's the computer that's the problem?
Old 02-21-2002, 11:26 AM
the wd 100 gig with 8mb buffer seems plenty fast, playing 64 with medium density. at least when it was empty.
right now im doing about 25-40 tracks with edits every 16th and it holds up fine.
i have it in the g4, so noise is not a problem, it gets warm though.
Old 02-21-2002, 11:48 AM
I've disabled the second processor.
Reformated the drive with new 9.2.2os. Installed only pro tools and oms, And ever y time I open Pro Tools get error #2 and or crash .
I Have the scsi 64 digidesign kit.
Other Programs like explorer and netscape are carshing (Error #2) [img]images/icons/grin.gif[/img]
Old 02-21-2002, 02:00 PM
clutch clutch is offline
how much ram do you have?
is each block showing correctly in the apple system profiler?
He used to cut the grass...he was a very nice boy...
Any dual G5 PPC's working well with 7.4? tbone63 Pro Tools TDM Systems (Mac) 8 07-23-2008 02:41 PM
Can I use Mix plus system on G5 dual 2 gig..... junkie666 Pro Tools TDM Systems (Mac) 0 04-05-2004 10:35 AM
Protools 6.22 and G5 dual 2 gig working well ! MAXIMUSIC Pro Tools TDM Systems (Mac) 23 12-21-2003 09:16 AM
I need a DUAL-CPU system! Barhab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 07-13-2003 06:33 PM
Working with dual monitor AGP card on G4 Bastik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-14-2002 02:31 AM
