Old 10-27-2008, 07:54 PM
bootyt bootyt is offline
Default Crashing when I open File
I recently had my MAC repaired and am in the process of re-loading EVERYTHING!
I re-installed my Software (M-BOX 6.2)..I know it's old..but it's been working just fine!
When I open Pro-Tools..everything seems fine until I attempt to OPEN a FILE from my external hard-drive!
As soon as I click on the FILE....the entire screen goes DIM...and I get an error message in a grey box that says
"You need to restart your computer. Hold down the power button for several seconds or press the restart button"
This message is also in French, German and Chinese!
It's happened 3 straight times....I'm stumped!
HELP!!!
BT
Old 10-27-2008, 08:26 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Crashing when I open File
You may want to post on the Mac forum?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-28-2008, 04:25 AM
Geez..I thought I did...can you tell me how to do that?
Thanks for the help.
BT
Old 10-28-2008, 08:30 AM
DigiTechSupt's Avatar
I moved it to the correct forum.
Can you tell us which model Mac, which OS version and which Pro Tools version you're running? Most likely you just have an incompatible version of Pro Tools installed.
Avid Audio Tech Support
Support FAQ
Old 10-28-2008, 05:48 PM
Thanks for getting back to me...here's the thing. I've been using this version of Pro-Tools on this MAC for years. I just had the hard-drive replaced..and a new logic board installed. Nothing else has changed. I'm still running MAC OSX 10.3.9...and i simply re-installed my original MBOX Pro-Tools software (6.1)
I tried to open a project I had been working on just a few weeks prior.
Something must be different with my MAC...I just don't get it!
Very frustrating. I don't think it's a Pro-Tools issue..I think it's the MAC.
But the Apple people can't help me with my Pro-Tools issues!
UUugghhhhhhh!
BT
Old 10-29-2008, 06:49 AM
Phil Ogden Phil Ogden is offline
Looks like you need a minimum of PT6.2.2 to run under Panther OS (you mention 6.1 in your last post). Not sure why it may have worked in the past.
http://www.digidesign.com/index.cfm?...4&itemid=23639
http://www.myspace.com/philogg
Cannot open any session without crashing. ReachMusicProductions Pro Tools 11 12 10-02-2013 11:59 AM
Crashing when open Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-20-2009 03:43 PM
PT crashing on session open Clockwork Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 08-13-2008 10:19 AM
Crashing/Won't Open. Please respond as quick as po Jasperdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2005 09:19 AM
Can't Open/Create new file from File Menu nob turner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-07-2003 11:04 PM
