A compressed question !!!!
Ok!
Here i go again! When i use an external compressor(Blue max)(exelent!) in pro tools the return signal is really hot but in the good way and i saw that i can really push the output of the comp. And the input fader don't clip.And the dynamics still there clearly good. But when i make the same internally with the digidesign compressor if i push the output gain there is the clip adn the dynamics fly away.There is something that i made wrong? Did the plugin is not supossed to work like the real one? I have tried a lot of compressor settings. Please Help with some tips . Other question is my mixing drum. Ok i use 7 microphones to rec the drums. When i rec all.I made an stereo auxiliary track and bus all the drum tracks to this aux track to make the compression for the drum. Thanks!
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Re: A compressed question !!!!
Digi plug doesn't have an output level control,
only input(as you noticed), and yes you are able to achieve more gain with output of stand alone compressor cranked. But sometimes louder is percieved as better,wich might not be true if test was done with equal volume/loudness. A good way to use your output level is to have it match the uncompressed level(bypass) unless of course it's a live gig with an underpowered P.A. and you need extra gain. |
compressed audio? | haderach | Digidesign Hardware & Software | 4 | 03-18-2005 04:42 PM |
9073 on 6.1 no compressed folders, no SP2, | mac goD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-14-2005 02:37 AM |
Let's talk about compressing pre-compressed tracks | spicyitaliano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-19-2004 09:46 AM |
backing up in compressed formats good/bad? | antiphase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-01-2003 12:41 PM |
IMA 4:1 compressed audio algorhythm | babyseal | Pro Tools TDM Systems (Mac) | 3 | 04-06-2001 08:07 AM |
