Old 08-01-2007, 11:53 AM
guitar131 guitar131 is offline
Default Monitoring with hardware reverb while tracking dry with 002
Is there a way to do this using Low latency mode or a higher buffer rate? Just curious, although the 128 buffer isn't too bad with a software reverb while tracking. Thanks...
Old 08-01-2007, 02:44 PM
3JDamon 3JDamon is offline
Default Re: Monitoring with hardware reverb while tracking dry with
I generally use outboard preamps feeding the S/PDIF input, and send the analog outputs of my interface and the preamp to a small mixer where I can add effects ad nauseam, hardware or software. Add software reverb on an aux track fed from a pre-fader send with channel muted, add hardware reverb on mixer's aux send/return. It's OK if a software reverb has some latency to it, as long as the dry signal doesn't.
With a 002 you could use insert-splitter cables (output end is 1/4" TS, insert end is 1/4" TRS with R&S soldered together) which will send the dry analog input out for monitoring without cutting off the signal to the converters. Mix those with the 002's output, and you can track with a full plugin compliment.
Singers Want Reverb While Tracking Vocals... John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-10-2006 08:38 AM
low latency tracking with reverb stevejones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-06-2005 06:48 PM
Reverb while tracking. LurkerAtTheThreshold 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-21-2003 04:05 PM
Outboard Reverb WHILE Tracking Vocals The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-25-2002 09:40 PM
reverb while tracking jaceever 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-29-2002 09:52 AM
