Old 11-02-2008, 03:49 PM
eduardo_b eduardo_b is offline
Default Anyone using Mbox2 micro and iLok on laptop?
Digidesign says Mbox2 micro won't work well on hub (powered or not) and they are right. Great, but my laptop has only two USB ports, one being used by the wireless mouse. So, both the Mbox and iLok need to share the other. I was thinking a short USB cable with one male type A and two female type A connectors would be a solution. But I can't find one of these and I don't really know if this would work. The iLok seems fine on a powered hub, so I'm thinking a Y cable might actually be okay. Suggestions gratefully accepted.
It's not black, it's not white -- it's all grey
Old 11-03-2008, 05:03 AM
Steevp Steevp is offline
Default Re: Anyone using Mbox2 micro and iLok on laptop?
I solved the USB problem like this:
http://cgi.ebay.co.uk/USB-2-0-PCMCIA...742.m153.l1262
Works a treat.
www.Krankschaft.com
Windows7 64bit, RME UCX, Asus Z97-P, i7-4790K@4.00Ghz, 32GB Ballistix Ram, Console 1, Unity Audio Rocks, RME UCX.
Old 11-03-2008, 11:50 AM
DigiTechSupt's Avatar
Why not connect the Mbox directly to one port, then use the hub for the wireless mouse and iLok?
Avid Audio Tech Support
Support FAQ
Mbox2 Pro & Mbox2 Micro on the same system Freakazoid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-16-2011 01:38 AM
mbox2 micro Y.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-30-2010 05:00 PM
Mbox2 micro Famasha77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-15-2008 11:25 AM
Old MBOX2 Micro sureno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-23-2008 01:14 PM
