Old 07-12-2018, 12:04 AM
its2loud its2loud is offline
Default Re: Netflix delivery file
Pro Tools doesnt care what audio is actually in the waveform for each channel. It only has a specific order for the channels in 5.1, 7.1, etc. Therefore, if you want the layout to be different than what ProTools specifies then you need to order it manually on 8 mono tracks first. From top to bottom
Left
Center
Right
Lfe
Ls
Rs
LT
RT
Then take all of those clips in the mono tracks and drag them onto the 7.1 track in that order. Now, the audio will be in the correct order for delivery and export from ProTools.
You can then rename the file once exported.
Obviously, if you re-import this file into ProTools it will assume its the proper native track order and rename accordingly.
Old 07-12-2018, 01:46 AM
PhiBee's Avatar
PhiBee PhiBee is offline
That's exactly what we did, individual tracks that we reorganized into a 7.1 track.
But when they received it, everything was disorganized.
For us, Pro Tools users, it works when re-import, but in their process, no.
No matter, with Quicktime, it did the job :), even if we spent more time...
If someone could write a script to automate this manipulation under QuickTime, it would be cool :) Yes, ok, I dream ...
WIP house Prod - home studio
iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61
STUDIO PRO Post-prod
MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic.
Old 07-12-2018, 08:02 AM
Glad the Quicktime worked. There are many things the Netflix QC process needs improvement on. They “fail”a lot of things that aren’t actuall issues. Unless you tell them outright they will make you do it again which wastes a lot of time and resources.
Old 07-18-2018, 08:38 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Time Factory 2 might also be able to do this.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 05-09-2019, 03:53 PM
dieborn dieborn is offline
I'm having the same issue. Please, can you share how it worked for you in Quicktime? How did you import in Quicktime the 5.1 and LT RT and then exported a .mov container? Thanks
  #16
Old 05-10-2019, 02:11 AM
PhiBee's Avatar
Hi. Unfortunately, I'm on vacation for 3 weeks now! Are you in a hurry ? I will try to reach my colleague
WIP house Prod
  #17
Old 05-10-2019, 02:32 AM
PhiBee's Avatar
Ok, I found the doc on my laptop. Here it is: https://www.dropbox.com/s/9bi36yh4a6....mov.docx?dl=0
It's not an easy way, but it works. Thanks god we don't have to do that too often (ok, we had to do that just one time!)
Be aware that it is in french, so you will have to play with google trad
Hope it helps.
  #18
Old 05-10-2019, 12:59 PM
Hi Phibee. Thanks a lot for your help!! Finally I can delivery the file!
  #19
Old 05-10-2019, 01:20 PM
Hi PhiBee, Thanks a lot for the help! Now I can finally deliver this!
HTML code is On
Netflix deliverables. TVPostSound Post - Surround - Video 11 05-16-2018 02:39 PM
Mixing for Netflix Etc jeremiahmoore Post - Surround - Video 2 05-02-2016 10:08 PM
Avid-- Pay attention to NETFLIX brickroadstudio Pro Tools 10 37 10-27-2011 10:39 PM
Internet File Delivery RecRoom Post - Surround - Video 18 03-30-2010 08:18 AM
M&E delivery ? Mark 66 Post - Surround - Video 7 05-11-2007 09:39 AM
