Old 04-06-2005, 10:47 PM
mach-1 mach-1 is offline
Default What Drum Samples for \'Sound Replacer\' Plug-in?
I am curious what drum samples anyone uses for the Sound Replacer Plugin?
My dealer sold me the East West Drumkit from hell 2, but unfortunately the files are not recognizable from sound replacer. I need .wav or .aiff files.
What is everyone using? without having to record and chop up stuff to make a sound to use.
I appreciate the feedback, as I am quite dissapointed that the DKFH2 isn't readily compatible. Great stuff though, just not Sound Replacer Ready.
Thanks
Mach-1
Old 04-06-2005, 10:59 PM
malfunction malfunction is offline
Default Re: What Drum Samples for \'Sound Replacer\' Plug-in?
try this:
www.naturalstudio.co.uk
or try garageband, there's some good sounding samples in there but it obviously depends on the kind of music you're working with...or make your own...
Grant
PT9, Zed R16 & Macbook Pro i7 2.66Ghz
Old 04-07-2005, 08:06 AM
cwhite771 cwhite771 is offline
Download something like Sound Grinder or other audio conversion utility. This will let you batch convert files from and to pretty much any audio format required. Just convert them off the DKFH CD to your drive.
You can probably find a trial of Sound Grinder and other audio utilities at http://www.download.com/
Chris
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff.
Drum samples for Sound Replacer Blackers The Drum Room 9 02-12-2018 05:06 PM
Making Drum Samples from CD for Sound Replacer/Drumagog? millzboy Pro Tools M-Powered (Mac) 1 06-10-2010 03:54 PM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
Sound Replacer Drum Samples XCLAIM Tips & Tricks 27 03-02-2001 12:26 AM
