Old 05-11-2015, 06:22 AM
Atlanta Bliss Atlanta Bliss is offline
Default Matching sampled drums volume to live drums? any automated way to generate automation
Hi all,
I have a live drum track and have added a sampled kick and snare to the live kick and snare, I did this using the tab to transients and paste commands. Anyway, now my sampled kick and snare are in sync with the live kick and snare but the samples are all the same volume, I’m wondering if anyone can suggest a way to extrapolate the volume level of the live kick/snare and generate automation automatically so the samples will match them, or at least be pretty close. Any suggestions? I’m in Pro Tools 9.x at the moment, but will probably upgrade soon, so if there’s a workflow in PT12 that would be helpful too.
Any thoughts or advice would be greatly appreciated - Thanks!
Old 05-11-2015, 06:38 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Matching sampled drums volume to live drums? any automated way to generate automa
It seems to me that you would want to be using the Trigger plugin by www.slatedigital.com
Janne
Old 05-11-2015, 06:49 AM
amagras amagras is online now
This link may help better http://www.stevenslatedrums.com/trigger-ex.php
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
amagrasmusic.com
Thanks for the tip JFreak, I'm checking that out now.
Did you mean I should redo what I already have with Trigger, or that there's some way to just generate automation from it?
thanks again for your advice
Old 05-11-2015, 06:56 AM
Thanks Amagras!
Can I ask, are you using this yourself? Do you use the Slate factory sounds or your own samples?
Could I ask your workflow, if you have a moment to explain? I have general problems at the moment with finding ways to get drums done - both when I have a live drum track I want to add programming to, like in this case, but also when just making beats from scratch using samples etc. So I'm just trying to learn about the different approaches others are taking using PT.
thanks
Old 05-11-2015, 07:11 AM
I don't use any triggers but if your drum has been recorded in a multitrack and you have separate tracks for snare and kick I don't see any reason for not using it. Triggers usually imitate the dynamic of the original instrument so you don't need to worry too much; you can also blend both sounds if the trigger has a mix control or by just duplicating the track and routing both to a Aux send. Just make sure to tune the samples so they have the same harmonics.
amagrasmusic.com
Old 05-11-2015, 07:19 AM
Thanks,
I am going to get this plug in .... or maybe the Massey Drum Replacer one (not sure which is better, will investigate) ....... in this instance though I already have the sampled drum tracks and the live ones (they are multitrack) in time so am wondering if there's someway to get the fader of the sampled track to somehow ride so the volume matches the live track - ? I was wondering if maybe Waves Bass Rider plug in might be able to do this? Or there might be some side chaining technique or ??
Old 05-11-2015, 07:21 AM
Sidechain could do it...
amagrasmusic.com
Old 05-11-2015, 07:50 AM
I could sidechain a fader somehow? I'm sure this is possible somehow, just trying to think of a way
Old 05-11-2015, 08:54 AM
I don't think a fader would work like that but you could experiment sidechaining an expander to add some upward compression... I'm not 100% sure, tho
amagrasmusic.com
Matching automation points for volume trims JohnCatlin Pro Tools TDM Systems (Mac) 2 10-06-2010 01:39 PM
Using Sampled Drums in Windows PT - The best current options... Amerihudge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 04-25-2003 10:38 AM
Best sampled drums for use with PTLE halfloaded 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-01-2003 06:40 PM
Sampled Drums from hell Toontrack Pro Tools TDM Systems (Mac) 0 04-07-2002 01:13 AM
adding looped/sampled drums to session bryanbassett Tips & Tricks 0 10-29-2001 12:57 PM
