  #261
Old 03-29-2011, 09:56 PM
Danny Caccavo Danny Caccavo is offline
Default Re: HEAT (Harmonically enhanced Algorithm Technology)
FWIW, it's not based on Phoenix per se. it's a ground-up new set of algorithms. Yes, there can be some similar characteristics, depending on the settings, but this goes further (and better) than Phoenix does.
  #262
Old 03-30-2011, 04:04 AM
tomibraniste tomibraniste is offline
are you sure about that? I m not so sure
Web hosting
  #263
Old 03-30-2011, 04:36 AM
Firechild Firechild is offline
I AB tested HEAT and Phoenix and when using the "Iridescent" plugin I was able to get a sound very similar to HEAT. But you can drive HEAT way harder but for me I´ll stick with Phoenix due to the fact that HEAT will be inserted to all your channel strips, consuming pretty much TDM power.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
  #264
Old 03-30-2011, 06:05 AM
Drew Mazurek's Avatar
I just installed a Magma chassis to continue using my old PCIx cards with PT9. I have the asset on my iLok but don't see HEAT. Do you have to "turn it on"? I've found nothing.
www.drewmazurek.com
  #265
Old 03-30-2011, 07:58 AM
WernerF WernerF is offline
I had the same questions.
You have to install HEAT. Once it is installed you will have the option to turn it on in the Options drop down menu. It is right under the turn on Delay Comp item. You then need to show HEAT in the View drop down menu and then click on the very lower right hand corner of the mixer page to show the HEAT master controls.
  #266
Old 03-30-2011, 09:04 AM
Where can I download it?
Do I have to request the 30 day trial?
www.drewmazurek.com
  #267
Old 03-31-2011, 07:20 AM
That may be the only way to get it. I'm not totally sure though, as I already had gotten the demo and tried it when I decided to buy it. It makes sense though to just go ahead and request the demo, if you can't find another download, and your iLok will just permanently authorize it once it's installed. Whatever works.
  #268
Old 03-31-2011, 07:51 AM
Thanks.
I had a friend email me the installer.
www.drewmazurek.com
  #269
Old 03-31-2011, 02:42 PM
Cool.
  #270
Old 05-10-2011, 02:46 PM
jpd52 jpd52 is offline
Someone please enlighten me as to where to adjust HEAT from?
Braindead,
Thanks,
Jon
[email protected]
A direct email would be more than welcome..
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
9.0.2 crashes when setting X-Form algorithm A Chapman macOS 3 03-22-2011 08:38 AM
Melodyne algorithm unhappiness thread kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-26-2009 02:28 PM
Rhythmic algorithm Steve MacMillan Pro Tools TDM Systems (Mac) 3 11-28-2007 10:44 AM
positional scrubbing algorithm? KingTor Pro Tools TDM Systems (Mac) 0 06-05-2000 01:04 PM
