Protools instantly "unexpectedly quits" and wont open at all
Tried restarting the computer, still no such luck.
It was working fine a few weeks ago. Only thing i can think of that may be messing with it is that i recently downloaded the Coreaduio driver. Does anyone know what i can do to get protools open again? Thanks |
Re: Protools instantly "unexpectedly quits" and wont open at all
Pro tools quits unexpectedly "solution"
At least it was for me, and it was NOT found on THIS site by my eyeballs, but I will be corrected I am sure. But it bears mentioning NONE THE LESS! Recent Mac systems operate with a 64bit processor by default, and Pro Tools is a 32Bit program. They will "somewhat" work together for a week or so, but with some wonky results. DAW errors, tracking lines are off by an inch, and eventually the crashes come on To put your Mac in 32 bit mode, hold down the "3" and the "2" key together while booting up. It will stay in 32 bit mode from then on. To go back to 64bit mode, hold down the "6" and the "4" at the same time while booting up and you are back(why, I dont know, if you are using pro tools) That took me 2 weeks to solve, but my updated LE8.0.4cs is working like a champ. I dont wanna be a geek, I just wanna make music.... Adam http://www.youtube.com/user/tx644 Mac I7, 2.93ghz, 4GB ram, MBox2 P.S.//// 32 bit mode only uses so much RAM, so if you have 4 GB of ram, YOU ARE GOOD TO GO! Do not waste your money on bigger chips(like I Did) Until you are running 64bit Music Software, save your money for bribing the A&R guy's friend's friend. LOL |
Pro Tools LE 8 "quits unexpectedly" at launch, after reinstall, and database delete | MWPOP | macOS | 10 | 08-19-2013 05:19 PM |
Problem: Protools.exe sits in Task Manager "Processes" Tab but wont open | andy_eade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 08-28-2012 05:34 PM |
Pro Tools 9 "Quits Unexpectedly" on start, when loading Plugins! | dbC4G | macOS | 6 | 04-06-2012 05:51 AM |
Pro tools quits unexpectedly "solution" | AdamArnold | Pro Tools TDM Systems (Mac) | 5 | 11-19-2010 09:20 PM |
Pro Tools le 6.0 (and 6.0.1) hangs on "setting up Midi"-- then unexpectedly quits | rdatman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2010 09:15 PM |
