Old 11-08-2019, 12:15 AM
bsteeve bsteeve is offline
Default Re: What brings Dolby Audio Bridge to HDX users?
Originally Posted by LDS View Post
I tried setting up an IAC bus but couldn't get it to work. I also tried sending the midi directly through physical midi I/O using a cable and a MOTU 4x4... and I tried output LTC via audio into Lockstep, which then converts that LTC audio to MTC. Lockstep received the LTC audio... but I have mixed results with the resulting MTC making it into the renderer. I'll keep fiddling with it and see if it sorts itself out... but even then, MTC isn't frame accurate.
Yep this is not working for me either... had to generate an LTC wav file to get it to sync with the renderer.... but with MTC through IAC Bus 1.. no go, does not work.
Anyone got it working with MTC? What is your magic trick...?
I'm running an HDX2 with an MTRX
Old 11-08-2019, 07:21 AM
Adam at Dolby Adam at Dolby is offline
Have you tried deleting and re-adding the port in Audio MIDI setup. I've had to do that to get this working.
In Audio MIDI setup, MIDI Studio, IAC Driver, IAC Properties, Add and Remove port - delete the existing bus with the minus key, re-add with the plus key so it shows IAC Bus 1 and make sure Device is Online is checked. Go back to Pro Tools, Peripherals, Synchronization and set the Generator to IAC Bus 1.
Old 11-08-2019, 07:38 AM
Hi Paolo, Separate issues altogether. Atmos Content Creation Tools are an important but small part of what Dolby Labs does altogether so it is a matter of resources - eng, QA, support and fitting into existing sales/system models. We also believe that our dealers selling configured systems provide added value and services in supporting our products and helping customers with over-all Atmos studio needs.
Old 11-08-2019, 07:48 AM
Have you tried deleting and re-adding the port in Audio MIDI setup? I've had to do this to get it to work.
Audio MIDI setup, MIDI studio, IAC Driver, IAC Driver Properties, Add and Remove ports, remove with minus, add with plus, should display IAC Bus 1, make sure Device is online is checked, reselect as MTC Generator in Pro Tools, Peripherals, Synchronization, MTC Gen online in transport window.
Should work.
Old 11-08-2019, 12:53 PM
ChrisMac ChrisMac is offline
anyone try the Source Elements LTC plug to send TC? https://source-elements.com/products/source-ltc
Chris McIntosh
President/Sound Supervisor
Postal Audio Inc.
Imdb
Facebook
  #16
Old 11-09-2019, 03:48 PM
paulo m's Avatar
paulo m paulo m is offline
Related:
https://www.pro-tools-expert.com/pro...ent-4682714898
View comments below the article.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
  #17
Old 11-09-2019, 06:37 PM
Should work.
No I haven't, I'll try that when I get back in the studio. Thanks for the advice
  #18
Old 11-15-2019, 07:32 AM
huub huub is offline
Routing MTC internally works fine for me using the IAC bus.
Don't forget to go to peripherals to assign mtc to the IAC bus.
Huub
  #19
Old 11-15-2019, 07:41 PM
Originally Posted by paulo m View Post
Related:
Thanks Paulo, have to give it a try
Chris McIntosh
Postal Audio Inc.
Imdb
Facebook
  #20
Old 12-06-2019, 04:46 AM
spoons's Avatar
spoons spoons is offline
(null)
This is working for me also. Might sound dumb but check the Renderer and PT are set to the same frame rate , that initially caught me out.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
HTML code is On
Neyrinck Broadcast Supreme Bundle: Dolby E, Dolby Digital & Pro Logic John McDaniel Buy & Sell 1 10-20-2014 06:39 AM
Each new bit of knowledge brings more ??? Terry Wetzel Pro Tools 9 3 12-17-2011 06:04 AM
Import Session data brings undesirable audio regions Alécio Costa Pro Tools TDM Systems (Mac) 1 11-21-2007 07:56 PM
New Dolby Encoder:Any Users? MusoPro Post - Surround - Video 11 11-24-2005 03:59 AM
HD users need DTS and Dolby Digital encoders soon! poldo Post - Surround - Video 2 06-11-2002 10:31 AM
