Pro Tools 2019.5 & Mojave crashes every time
Tried to open PT 2019.5 20 times now, crashes every time...
Re: Pro Tools 2019.5 & Mojave crashes every time
same here - check plugins - I removed izotope and everything was working fine!
Izotope Post Production Suite 3 here in use (2019.5/latest Mojave). No problems.
I have worked 9 hours now without a single problem. So might be something else. |
So, here is the strange thing - I have 2 administrator accounts. PT2019/Mojave open just fine in one, but not in the other (the one I use all the time, of course...!). Why might that be?
Latest - I can now open a blank session directly from the PT application, but can't open existing sessions.
Are you using an approved mac? Have you done the troubleshooting tips?
I upgraded last night on a 2018 mac mini and everything has been perfect so far.
2018 Mac Mini 3.2GHz 6-core, 32gig ram - OSX 13.4 - Protools Ultimate 2023.6.0 - HDX PCIE in Sonnet Thunderbolt 3 box - Apogee Symphony Mk1 |
Yes, I'm using the same iMac 2013 as usual...
Is it Protools standard or ultimate? It seems only 1 of the 2013 imacs are supported for ultimate.
Supported Processors (Pro Tools | Ultimate, Pro Tools | HD & Standard): Late 2013 27" iMac14,2 Quad-Core i7 'Haswell' 3.5 GHz Supported Processors (Pro Tools Standard only): Late 2013 21" iMac14,1 Quad-Core i7 'Haswell' 3.1 GHz Late 2013 21" iMac14,1 Quad-Core i5 'Haswell' 2.7 GHz http://avid.force.com/pkb/articles/c...m-Requirements
Yes, it's the first one, should be fine. Thanks.
You're welcome! If it were me, I would do a fresh install of everything at that point. Hope it starts working for you!
2019 iMac i9 + PT 2018 + Mojave | rwbreck | General Discussion | 41 | 11-22-2019 01:13 PM |
PT 2019 Mojave macPro 5,1 | off the wall | Pro Tools 2019 | 20 | 05-13-2019 06:00 PM |
new SSD for PT 2019 and Mojave question. | Anibal | Pro Tools 2018 | 0 | 05-09-2019 09:14 AM |
Pro Tools 8 crashes all the time!!! Please help!! | felix922 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-24-2011 08:26 AM |
