Old 02-08-2012, 09:41 AM
lacassius lacassius is offline
Default PT9, Apogee duet help please
So i just got an apogee duet and upgraded from pt8 to 9 so i could use it. Now when I try to arm a track it says "the track couldnt be record enabled because it doesn't have an active input and output assigned". Ive tried everything I could think of and can't fix this issue.
please help I have 24hrs left to test this mic before i lose the ability to return it and I can't test it because i can't record anything.
Old 02-08-2012, 10:30 AM
tomhartman tomhartman is offline
Default Re: PT9, Apogee duet help please
I guess the most logical question is what do you have assigned for the input and output of the track? This has nothing to do with the Duet, which I've used with PT9 just fine.
Old 02-08-2012, 10:50 AM
i dont understand what you mean. in pt8 when i set it to input 1 that was the xlr of my mbox..i didn't have to assign input 1. maybe thats changed with pt9..if so how do i assign input 1 to input 1 of my duet which should be the xlr input.
Old 02-08-2012, 10:57 AM
all of the input things on each individual track is dark. the output 1-2 right under it is lit up and works fine. i can playback music through it no problem. when i right click on the input1 and click on make active it says "could not be made active because input path is not available". no idea what that means
Old 02-08-2012, 03:44 PM
nobody knows the solution?? nobody has come across this problem before??
Old 02-08-2012, 07:51 PM
ripple FX ripple FX is offline
First make sure you install the driver for the Duet.
Then with your session open, check that your Playback Engine is set to the Duet.
Hope this helps,
Chris
http://www.ripplefx.com
Mac Pro 8 core 3.0GHz Harpertown
Magma PE6R4I - HD 3 Accel +1 Process
Control 24 - 96io - 1622
OSX 10.6.8 - PTHD 10.3.10
Apogee Rosetta 200 (MINT), Lynx AES16e-SRC, Apogee Duet, BBE 882i, OFFERS ENTERTAINED jrhager84 Buy & Sell 5 03-11-2013 01:25 AM
Pt 9 and apogee duet 1 sidneyjohn Pro Tools 9 1 02-21-2013 09:07 AM
WTB:WTB: Apogee Duet 2 postman56 Buy & Sell 2 09-21-2012 05:37 AM
Apogee Duet 2 is out! nst7 Pro Tools 9 2 03-31-2011 12:23 AM
Apogee Duet with PT LE ? chicken 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-23-2007 04:57 PM
