Destructive Record punch-ins slightly out of sync.
I cannot for the life of me understand while dropping to record on this session resulted on punch-ins to be slightly out of sync and creating glitches on the drop-in rec point. I know I must be forgetting something - I am quite tired - but I cannot point out what I have not selected.
Re: Destructive Record punch-ins slightly out of sync.
record pass compensation will correct the converter latency... so will be a small effect. How much (in samples at what sample rate) are things out? That will be a clue for folks here. And what is the IO buffer size?
I have had this problem with destructive punch but not with destructive record. I'm curious to see other issues.
sent from a stupid phone using Tapatalk |
Yeah, I just upgraded from 12.4 which I had been on forever because it was so stable to 2018.10.0 and was surprised to find out my destructive record workflow was no longer working the same.
In 12.4 I used to command + control click my record tracks to turn the delay comp to blue, that way I could destructive record smoothly with no pops or clicks (and with a 2-sec pre and post roll). Suddenly in 2018.10.0 this wasn't working, my destructive record punch-ins sync was off creating clicks, and my compensation values were changing, regardless of whether I clicked my record tracks to blue or not. I was getting pops everywhere and it was driving me crazy. What I found to be the solution was NOT to command + click the tracks to turn them blue, instead leave them with their normal delay compensation on as usual, and set all the record tracks into Input Monitor mode. Once all my record tracks were in Input Monitor mode when recording everything flowed right and had the right delay compensation and there were no clicks or sync issues and everything recorded as normal. I still use my 2-sec pre and post roll for safety, but everything worked right with destructive record doing it this way. This has been my findings so far, I haven't had much time to delve deeper, and I just upgraded to 2018.10.0 so I'm not sure what is normal functionality or what is being wonky, so I'd be curious to hear from everyone else, but this has been my discovery so far. I hope this helps. |
I've been working in Input monitor mode and using Destructive Record. PT 2018.7 and now 2018.10. 2:00 pre and post roll, no pops. But I'm not using any hardware inserts.
~Will |
Frustrating. I miss mag dubbers. :)
I was having trouble with Destructive Punch for awhile and was resigned to rerecording after the producers had left. This last mix, though, I changed the whole clocking setup on our stage AND stumbled on Quote:
I'm assuming you both mean no pops or bad punches when you play back since input monitoring doesn't let you hear the punch. Right?
Correct. I usually save my record range as a memory location so I can check playback. I started using destructive record when I had trouble with Destructive Punch - I guess I should try DP again.
~Will |
Destructive Punch & Transport Record Lock broken in 12.3? | reichman | Pro Tools 12 | 6 | 02-26-2016 04:51 AM |
Destructive Punch & Transport Record Lock - NEED OPINIONS | reichman | Post - Surround - Video | 8 | 11-25-2015 08:41 AM |
Destructive Punch Record-Custom lenght of track? | Eric L | Post - Surround - Video | 8 | 08-18-2007 10:42 AM |
Pops on punch out of destructive record | CD Productions | Post - Surround - Video | 17 | 01-29-2007 07:08 AM |
Destructive Record ('Click' sound when using punch | Flingus2001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-12-2005 05:38 PM |
