Old 03-07-2012, 01:46 PM
bunderson bunderson is offline
Default Pro Tools Reboots PC every time during launch/loading of plugins
OK fresh install of Win 7 64bit, fresh install of PT9 using Delta Audiophile 2496.
Haven't actually been able to get into PT yet as it crashes/reboots my PC every time I launch the program. I have tried removing plugins to the (unused) folder and still the same problem - I would presume it is not plugin related. Here we go again with hours and hours of trying to install the new version of PT. I should have learned my lesson by now and started using another DAW.
Any ideas?
Old 03-07-2012, 01:58 PM
Default Re: Pro Tools Reboots PC every time during launch/loading of plugins
SiSoftware Sandra
Computer
Model : Gigabyte GA-970A-D3
Workgroup : WORKGROUP
Host Name : protools-PC
User : protools
Processor
Model : AMD FX(tm)-4100 Quad-Core Processor
Speed : 3.62GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 16kB, Synchronous, Write-Thru, 4-way, Exclusive, 64 byte line size
L2 On-board Cache : 2x 2MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 64-way, Exclusive, 64 byte line size, 4 threads sharing
Computer
Mainboard : Gigabyte GA-970A-D3
BIOS : Award (Phoenix) F7 10/13/2011
Bus(es) : ISA X-Bus PCI PCIe USB
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : No
Total Memory : 4GB DIMM DDR3
Chipset
Model : ATI (AMD) RD890 PCI to PCI bridge (external gfx0 port B)
Front Side Bus Speed : 1x 196MHz (196MHz)
Chipset
Model : AMD 1600h
Front Side Bus Speed : 2x 2.35GHz (4.7GHz)
Total Memory : 2GB DIMM DDR3
Channels : 2
Memory Bus Speed : 2x 653MHz (1.3GHz)
Memory Module(s)
Memory Module : 4GB DIMM
Video System
Video Adapter : NVIDIA GeForce 7300 LE (4 PS3.0, 3 VS3.0 450MHz, 256MB DDR3 2x648MHz, PCIe 1.00 x16)
Graphics Processor
Storage Devices
WDC WD10EADS-98M2B0 (1TB, SATA150, 3.5", NCQ, 32MB Cache) : 932GB (C:)
TSSTcorp CDDVDW SH-222AB (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Hard Disk (C:) : 931GB (NTFS) @ WDC WD10EADS-98M2B0 (1TB, SATA150, 3.5", NCQ, 32MB Cache)
Optical Drive (D:) : N/A @ TSSTcorp CDDVDW SH-222AB (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ATI (AMD) IXP SB600 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700 LPC host controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : VIA M Audio Audiophile
Serial Port(s) : 1
Disk Controller : Giga-Byte SB700 SATA Controller [IDE mode]
Disk Controller : Giga-Byte SB700 IDE
USB Controller 1 : Giga-Byte SB700 USB OHCI0 Controller
USB Controller 2 : Giga-Byte SB700 USB EHCI Controller
USB Controller 3 : Giga-Byte SB700 USB OHCI0 Controller
USB Controller 4 : Giga-Byte SB700 USB EHCI Controller
USB Controller 5 : Giga-Byte SB700 USB OHCI2 Controller
USB Controller 6 : Giga-Byte SB700 USB OHCI0 Controller
USB Controller 7 : Giga-Byte SB700 USB EHCI Controller
USB Controller 8 : Giga-Byte 7023h
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 3.5
Performance Enhancing Tips
Warning 225 : CPU is not a production version but ES.
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 03-07-2012, 04:04 PM
Have you installed the driver for the M-audio card? Try holding the N key while opening PT and see if you can get to the window where you choose the audio engine, and see if you can select the M-Audio card, if its not already. If that's no help, maybe open up Device Manager and go thru each item and let it update drivers(connect to the internet for that).
Old 03-07-2012, 04:13 PM
Ok tried this and still get the blue screen of death.
Old 03-08-2012, 02:52 PM
Anarchill Anarchill is offline
type: avid refund on google and follow the steps ... they not supporting any AMD processor ... don't cry ... you will get yo money back as i do ... same problem ... but i got a AMD FX 8-core black edition ... they are quite stupid to not supporting AMD they loosing custumer fidelity
Old 03-25-2012, 01:24 PM
Hi Anarchill, I did get it working on AMD FX chip but had to do some BIOS changes. Basically, I disabled the automatic CPU boost and it works now. I still get the occasional freeze but only when I add certain plugins (luckily the ones that come with PT9 that I do not use anyway) but at least my new build PC now runs PT9.
Pro Tools 10.3.8 Crash When Loading Plugins jahylto Pro Tools 10 5 10-10-2014 11:13 AM
Pro Tools Not Loading New Plugins SteveWitt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2010 02:03 PM
Pro Tools hanging on startup at "Loading Plugins" Eric Gale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-03-2006 07:35 AM
Pro Tools Le 6.1 Crashes every Time I launch it ?? Pop-cycle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-04-2003 11:01 PM
6.1 reboots while loading in XP! Help!!! bcdigidesign75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-26-2003 06:28 PM
