  #21
Old 11-12-2020, 02:17 AM
Manaberry's Avatar
Manaberry Manaberry is offline
Default Re: Processor affinity
Originally Posted by EGS View Post
I've read a few posts about manually setting processor affinity. Are most Windows/Pro Tools users here currently doing this? Is it now considered standard practice? Thanks!
I have a 10980XE @ 4.4Ghz, so a pretty big CPU. At a buffer size of 32, PT 2020.9 goes crazy. General CPU load is around 60% with a lot of spikes running an 80 voices project with no plugins.
Removing core 0 and 1 from being used by PT with the Affinity Processor trick, the CPU meter went all the way down to 0-1%. I was blown away!
(I've tried Run as admin first but it didn't solve anything)
  #22
Old 11-12-2020, 04:31 AM
FunkzzaJ FunkzzaJ is online now
Wow
CPU meter in pro tools, or windows activity monitor?
When loaded like that, how does the PT CPU meter react to midi coming from external HW connected through USB? Any reaction, spikes?
My system reacts to external midi when loaded.
/FZZ
Skickat från min Moto G (5) via Tapatalk
Free beer tomorrow !!
- but until then -
we're stuck in the present moment
  #23
Old 11-12-2020, 06:16 AM
Manaberry's Avatar
Originally Posted by FunkzzaJ View Post
Wow
/FZZ
It was the PT CPU meter. The CPU activity from the Performance tab in the Task Manager was normal.
  #24
Old 11-19-2020, 11:28 AM
EGS's Avatar
EGS EGS is offline
Great!
Click for audio/video demo
Click for resume
  #25
Old 11-19-2020, 01:05 PM
EGS's Avatar
EGS EGS is offline
Any better solution? AVID? Thank you.
Launch Protools
Ctrl/Alt/Delete/TaskManager/Details
right-click ProTools Set affinity un-check 0&1
right-click ProTools Set priority High
Click for resume
  #26
Old 11-20-2020, 10:25 AM
The Weed's Avatar
The Weed The Weed is offline
Not sure about setting Processor Priority automatically, which I don't use, but you can set Processor Affinity automatically with a command "switch" in the Target box of the Shortcut Icon. I believe I linked to a YouTube video on how to do that in this thread.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #27
Old 11-21-2020, 07:11 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by The Weed View Post
...you can set Processor Affinity automatically with a command "switch"...
Yes, I get that this helps streamline the affinity work-around process. But I'm asking if AVID will give us a for-real fix. Getting the best PTools performance should not require us to dive into the depths of OS/CPU utilization. Several versions ago we had CPU optimization options right in the Playback Engine ... they took it out for some reason. AVID? Mods?
Click for resume
  #28
Old 11-21-2020, 07:14 AM
EGS's Avatar
EGS EGS is offline
We used to have options for "# of Processors" and "CPU Usage Limit" in Playback Engine. Why are these options no longer available?
Avid?
Anybody?
Click for resume
Win 10; PT 12.5.2; Processor Affinity ejinbc Windows 8 08-01-2016 12:33 PM
CPU Spikes, 12.5, and processor affinity... Work-Around? 59.9hz Pro Tools 12 12 07-22-2016 10:42 AM
Dual core problems with old 6.x rig. Affinity problem. scoobydoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-24-2007 08:12 PM
Set processor affinity fixed -9092, -9093 issues philwinkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-31-2006 08:33 PM
Dual Core Processor Affinity / 9093 9094 9129 ikelk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-21-2006 01:31 PM
