ALT + TAB will not toggle between programs in Windows 10 When Pro Tools is open
In PT12 (on Win10) when I try to "Alt, Tab" out of PT and into the last used window it will not work. I think this is because PT is using ALT and SHIFT as modifier keys for Pro Tools functions and stop the O/S function of toggling b6etween windows.
Re: ALT + TAB will not toggle between programs in Windows 10 When Pro Tools is open
PT "owns" the keyboard. Try moving the cursor so that it is over the Taskbar, outside of PT, then try Alt+Tab.
Thanks for your reply. I know that this is a workaround, but it kinda defeats the purpose, as ALT TAB is meant for quick switching between windows. If I was going to the taskbar, I might as well click the desired window I want to switch to. Any other suggestions for overwriting this command that PT is controlling?
Interesting, I used to have this problem but it went away a while ago, I think upgrading to Windows 10 or PT12 helped but I'm not sure. Last time I had something like this there was a disc in the DVD drive.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Try alt-esc if you don't have too many apps open (though I don't know if PT10 passes any keys at all to the OS). The alt-tab thing works in the more recent releases.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Audio for other programs messed up when Pro Tools is open | imjtblanton | Getting Started | 1 | 05-22-2018 05:15 PM |
Toggle Mix and Edit windows | michaelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 06-15-2010 07:49 PM |
PT 7.2cs3 wont open after other programs have run. | SunsetLodge | Pro Tools TDM Systems (Mac) | 2 | 07-18-2007 04:04 AM |
PT playback stops when I toggle b/w programs | connbuds | Pro Tools TDM Systems (Mac) | 2 | 01-27-2003 10:24 AM |
windows won´t toggle | kalle74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 09-07-2001 12:29 AM |
