Old 06-29-2018, 06:59 PM
ToneSetter ToneSetter is offline
Default ProControl Time Counter Display (how to fix or where to get)
Does anyone know how to fix the time counter display on a digidesign procontrol or where I can buy a replacement? The bottom left segment of the minutes is not working. It affects the 0, 2, 6, and 8. The link to the video showing it is below. Any help would be greatly appreciated.
https://youtu.be/PCSZ_sAx_ik
Old 06-29-2018, 07:52 PM
bcwiz's Avatar
bcwiz bcwiz is offline
Default Re: ProControl Time Counter Display (how to fix or where to get)
Each digit is a single digit display pc mount, the part is a Para Light C-401G
Old 06-29-2018, 08:26 PM
Thanks for the reply. Do you by chance know where I would purchase one?
Old 06-29-2018, 09:04 PM
bcwiz's Avatar
Here's the US distributor https://www.paralightusa.com/c-a-401...t-display.html
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
Old 06-30-2018, 08:24 AM
Thank you!
Old 09-18-2018, 08:23 PM
I got a pro control main unit for parts to replace the time counter display on my other main unit but don't know how to and don't want to go in blind and break something. Can anyone explain how to switch out the time counter display from one unit to another? Thanks in advance for the help
Old 09-19-2018, 08:08 AM
bcwiz's Avatar
You need to remove the meter bridge from the main frame to access the pcb that holds all the metering and counter display. Each digit of the counter is a separate device that is soldered to the board. Here's some pics of the pcb. (pics are upside down)
Brian Campbell
Old 09-19-2018, 07:58 PM
Got it replaced thanks to YYR123's PM and bcwiz's reply. Thanks guys!
Old 10-25-2018, 04:43 PM
ibanman555 ibanman555 is offline
Did you obtain the Para Light digits for replacement? If so did they match the fit and color/brightness of the originals? I too need a replacement but I'm thinking of using another color, or I might stick to stock.
Old 10-26-2018, 02:14 PM
YYR123's Avatar
YYR123 YYR123 is offline
Cool glad it worked out for you.
Daniel
Counter display blank when opening session Armando ICON & C|24 2 03-06-2013 03:17 PM
Display Counter Externally on 002 CeeBee Pro Tools TDM Systems (Mac) 2 01-11-2006 03:16 PM
Display time counter externally CeeBee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-11-2006 09:59 AM
New FREE Pluggo - Timecode Counter Display jkaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2002 06:20 AM
Display counter pauses (new) JimLeb Pro Tools TDM Systems (Mac) 2 05-25-2001 09:00 AM
