Old 10-24-2003, 10:57 AM
jdolan jdolan is offline
Default Why did my audio speed up?
Does anyone know why, after I bounced to disk, the stereo track would be faster? It is fine when I import it back into PT, but faster and higher pitched when I play it back on cd or anything other than PT. Also, I've had some problems w/ whole projects playing back slower than they should...
Any help or suggestions would be appreciated.
Jon
Old 10-24-2003, 11:12 AM
Default Re: Why did my audio speed up?
Whenever you use a digital source (external converters, or whatever).. you have to make sure that the sample rate of the digital source matches the Pro Tools session sample rate.. otherwise you'll have sound files recorded with the sample rate which is the external source's sample rate.. but the header is set to the sample rate of the Pro Tools session. Also, never run Pro Tools in "external clock" mode without having a clock source.
This has been discussed numerous times before on the DUC.. do a search. Try searching for the phrase "Header Investigator" which is a utlity I wrote to change WAV files' header nformation.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-24-2003, 11:01 PM
Thanks so much, Rail. I will try that. The searches that I did weren't turning up anythin relevent. I appreciate it!
Jon
Audio comes out at different speed/pitch! PLAbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2005 07:14 AM
IS IT POSSIBLE TO SPEED UP OR SLOW DOWN AUDIO FILE pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-06-2005 08:59 PM
Adding speed to audio BreezNess 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-18-2001 06:28 AM
Audio CD Burn Speed shadowbox General Discussion 2 02-17-2001 07:10 PM
Audio Speed Ramp shawnyashar Tips & Tricks 4 06-05-2000 08:41 AM
