Old 06-06-2018, 06:00 AM
TauTau_de TauTau_de is offline
Default Eleven Rack Midi issue (program changes delayed)
I have an Eleven Rack and wen use a sequencer on stage. I also use a Behringer 1010 with a different chipset. The Behringer pedal switches presets, which by itself is no problem. However I also want to use the MTC from the sequencer (Reason) to have tempo information in the 11R.
I tried an old Yamaha MidiMerger as well as the merge functionality of the Behringer Pedal, both show the same problem: When I swtch presets, the switch doesn't occur instantly, but really delayed (up to 30sec). As soon as I stop the sequencer, everything works normally again.
Is the 11R somehow flooded by the MTC messages, so that the program switches "can't get through"?
Issue with Eleven Rack & 003 paul_g Pro Tools 10 5 08-28-2019 05:43 PM
Issue w/ Eleven Rack UndergroundLab Eleven Rack 1 04-09-2017 11:06 AM
Issue with i/o after eleven rack use jimbridgman Eleven Rack 2 02-11-2014 09:14 PM
Eleven rack issue dndunlap Eleven Rack 4 03-08-2011 11:35 AM
Eleven Rack with HD issue Touchwood Studios Pro Tools TDM Systems (Mac) 6 10-09-2009 12:22 PM
